Tags:
  1. Richard24
    When flying away from home where you can't save your movie data, how can I transfer movies to a external device from being away from home.
  2. RémyHeli
    Usually people just swap with another memory card, easy, safe and super quick.
    Richard24 likes this.
  3. Richard24
    Does sound very simple, I will do that...thanks.
  4. Richard24
    Do you use the Litchi App at all?
  5. RémyHeli
    Not yet! Any question just ask - I know many using Litchi here.
    PS: format any additional sdcard in advance by using related option in Go App.
  6. tcope
    Salt Lake City, UT
    There are also external drives that will backup from an SD card. However, a 32GB card is about $20. I think a 64GB card can be had for about $30. More cards work better for me as I leave 1 or 2 in the box with the Phantom just in case I forget to put the main one back in the drone.
  7. Richard24
    I'm just having a hard time trying to figure out what heights I have to set to make sure I don't crash into anything like tress etc....using the Litchi. Any tips. Thanks
  8. RémyHeli
    It seems that P4 last firmware has some issues with regards to altitude readings under certain conditions. Not sure if affecting Litchi but I understand that some users experienced issues with the craft not flying at expected altitude or not having enough time to climb between points set in Litchi mission.
    Recommandation would be to make sure there is enough margin with processed altitudes.
    #8 RémyHeli, Aug 26, 2016
  9. John Locke
    Yorba Linda, CA
    Buy 6 cards and store them in this. Works great, rugged, easy to find the case, easy to stow cards, easy to get cards.
  10. Fallguy
    400 feet above you.
  11. apd3984
    Auburn, Alabama
    I like that, plus if you had 6 SD adapters instead of regular SD cards, then you could carry 6 more micro cards on the SD storage side.
  12. John Locke
    Yorba Linda, CA
    I have two of those credit card sized holders. Although it's cool being so small to fit into your wallet, I prefer to keep my cards in my backpack. I've found those credit card sized holders get lost too easy in my bag, they are harder to find being so small. Have you ever had that moment of panic when you drive ten miles to fly and then you can't find your sd cards? That's why I switched to the larger holder. It also holds more cards, making it easier to segregate used cards from blank cards. Plus it's water resistant and more protective if I were to drop the holder out in the wild where I often fly from.
    #12 John Locke, Aug 27, 2016
  13. Fallguy
    400 feet above you.
Similar Threads - Flying away home Forum Date
Phantom 3 advanced started flying away Pro/Adv Discussion Sep 19, 2016
P3 Firmware Weak RC signal pops up and goes away when flying up close, does not affect phantom Firmware May 15, 2016
Auto take off and then is starts flying away on its own Standard/4k Discussion Apr 24, 2016
Flying away P3P Pro/Adv Discussion Nov 25, 2015
Warning lights and P2 not taking off with original control (but flying away with different control)! Phantom 2 Help Oct 20, 2015
