Fly home command?
Discussion in 'General Discussion' started by skeeter, Dec 10, 2013.
  1. skeeter
    Kingman, AZ.
    Noob question here.... Searched as much as I could from a tablet...
    Best practice to "fly home" when things go wonky? (I know it's a bit vague...) GPS mode, ATT?
    Thanks much!
  2. Gizmo3000
    Sherman Oaks, CA
    Best way to fly home (aside from turning off the Tx or switching to Failsafe for automatic Return Home and Land), is to enable IOC so that you can use the Home Lock feature. - then no matter what position he Phantom is pointed, if you pull back on the right stick (and stay at a safe altitude or go up in altitude), the Phantom will fly back towards you. Until it gets within 30ft at least.
  3. wfo211
    Home lock feature? Mind pointing me to the documentation on that? I don't recall hearing about that while watching all the pv2 vids on the DJI site. Thanks.
  4. skeeter
    Kingman, AZ.
    Thanks, Gizmo!
    How does one "switch to Failsafe"?
    And yet another nnooooob question: what does IMU stand for?
    Edit: Found the IMU abbreviation... Inertial Measurement Unit.... Methinks... So.... Much.... To... Learn...
  5. ericty
    I just learned about this a few weeks ago myself. It is a feature that is set to off from the manufacturer. You have to use the Naza Assistant software to enable it. Just go to the DJI site, under Phantom, look for the tutorial videos that show you how to enable the IOC (Intelligent Orientation Control).
    Good luck!
  6. OI Photography
    Clarksville, TN
  7. skeeter
    Kingman, AZ.
    Thanks! I'll check out the 3-part series ASAP!
    Edit. Just watched the vids. Excellent! Should be on a sticky and a must see for all of us sky virgins.
Similar Threads - Fly home command Forum Date
Homeowner in my Neighborhood claims I am trespassing if I fly under 500 ft above his house - legal? Rules and Regulations Aug 3, 2017
Should i fly my drone from home? Pro/Adv Discussion Jun 17, 2017
My Home point changed whilst flying with my Phantom 4 pro plus Phantom 4 Pro Discussion Jun 13, 2017
flying below takeoff point (home) Phantom 2 Vision + Discussion Jan 29, 2017
P4P+ Briefly out of control on return to home Phantom 4 Pro Discussion Jan 26, 2017
