Flight times on 100% charge
Discussion in 'Pro/Adv Discussion' started by almustafa, Jan 10, 2016.
  1. almustafa
    The advertised flight time is 23 minutes , does that mean running your battery down to below 10% to achieve, or does 23 minutes refer to the time when you get a low battery warning at 30%.
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    That's the max possible flight time while flying in the most ideal conditions. 18 minutes is more common.
  3. boolean
    I got 18 minutes today but that is when the 30% timer went off. I don't fly it much longer after the timer goes off. I have 4 batteries. I don't take any chances.
  4. Ken Hanks
    You can check the battery life of you battery if you press and hold the power button for at least 5 seconds.
Similar Threads - Flight times 100% Forum Date
MOR flight times! Phantom 4 Discussion Jul 5, 2017
DJI app closes sometimes during flight Control (Go, Litchi, etc..) Apr 22, 2017
Flight Log has incorrect timestamp Phantom 4 Discussion Apr 10, 2017
Mission Hub flight times Phantom 4 Discussion Jan 27, 2017
Random ATTI mode 2 times in one flight Pro/Adv Discussion Nov 3, 2016
