I went to check the flight path in the flight records but its not showing anything the counters moving and it shows the map but no arrow showing the path that was flown, am I missing something in a setting ?
I was talking in the app, all it shows is the launch location all data is stripped from the flight recordWhat do you see when you view your flight log here?
I cant figure out how to get the flight records out of the CS ,with IOS it was easierWhat do you see when you view your flight log here?
Right. I was thinking it might make more sense if you can see the actual data the app is trying to display. Perhaps there is no data to show.I was talking in the app
See this post for instructions.I cant figure out how to get the flight records out of the CS
Yes I tried the link I found that via a Google search but that dont work there is no info in the flight record folder and after searching a little more it seems my original reason for posting is a none issueRight. I was thinking it might make more sense if you can see the actual data the app is trying to display. Perhaps there is no data to show.
If I took the flights there should be data the only thing thats recorded is the launch location via the map in the app the folder in the CS marked DJI > pilot> flight record is emptyRight. I was thinking it might make more sense if you can see the actual data the app is trying to display. Perhaps there is no data to show.
Thank you , after a little digging online it seems the CS has problems recording flight records and showing the flight paths flown in the app but I was able to reinstall DJI Go 4 app on my ipad mini and sync everything and it works fine and flight records are intact so the moral of the story is if you rely on CS to save your butt one day ( when you lose your copter) you may need to be bailed out by a synced IOS device to locate your lost byrd via Phantom Log ViewerWhat do you see when you view your flight log here?
Great idea! Thank you for sharing your workaround.after a little digging online it seems the CS has problems recording flight records and showing the flight paths flown in the app but I was able to reinstall DJI Go 4 app on my ipad mini and sync everything and it works fine and flight records are intact
