Flight logs on my PC?
Discussion in 'Pro/Adv Discussion' started by Zdrone, Aug 30, 2015.
  1. Zdrone
    I enjoy looking at the flight logs on my mobile device, but am wondering if it is possible to get them on my PC to enjoy. Any ideas? Search has returned little to nothing.
  2. JBG
    JBG
    Android or ios?
    Sent from my Nexus 5 using Tapatalk
  3. acherman
    Alberta, Canada
    You can create a free Flytrex account and upload the .txt files there.
  4. Acbrian1
    Flight Replay - Flight Log Visualizer . I use this. I upload the log text files from my ipad to flightreplay and it does the rest
    Forgot, first upload the text files to Logs - Litchi and convert them to csv format, then send that to flight replay.. It sounds harder than it is.. only takes a couple minutes to complete whole process
    #5 Acbrian1, Aug 30, 2015
  5. Zdrone
    Android
    I used that healthydrones.com, very easy. I will check out the others, thank you
  6. Darmie
    Houston TX.
    Where are the TXT files located? I have an ipad air 2
  7. acherman
    Alberta, Canada
    Connect the iPad to iTunes, then select your device, and then apps, and scroll to the bottom o the right pane. At the bottom you will see Apps That Allow File Transfer and a pile of files for the Pilot/Go app (including stuff like your video cache if you have it turned on).
  8. Darmie
    Houston TX.
    Roger...
    Noted.
Similar Threads - Flight logs Forum Date
Can flight logs and battery info be erased or altered? Pro/Adv Discussion Dec 21, 2017
How To Delete Flight Logs Pro/Adv Discussion Dec 3, 2017
Downlink Restored messages in flightlogs Phantom SE Nov 29, 2017
How do the flight logs work? Phantom 4 Help Oct 4, 2017
How to download your Flight logs Phantom 4 Discussion Oct 1, 2017
