Flight limit
Discussion in 'Phantom 2 Vision Discussion' started by Pogimoto, Jan 6, 2015.
  1. Pogimoto
    Hey everyone, just would like to know what everyone has set their max height and max radius at? Because I took my pv2 up to max and warning light came on and stopped me at 200ft? Alright thanks.
  2. general01
    The limits are set in the naza software on the computer
    I set mine to 400 feet up and roughly a 500 foot radius
  3. RCRookie
    East Texas
    AFAIK... You cannot set the altitude above 400 feet... Radius is adjustable, but default altitude will not exceed 400 in the current revision, no matter what you set it to.
    However... You can "downgrade" to an earlier version (revision) when these limits were not set.
  4. Old Gazer
    Eastern Oklahoma
    I have my altitude set at 600 ft. And it will fly that high. My distance is set at 6000 ft.
  5. general01
    Hmm I will check with my p2v and if the limit is only 400 feet then I won't upgrade my p2v+
  6. Old Gazer
    Eastern Oklahoma
    You can set you altitude at whatever you want. Go to the limits in the assistant. When you set your altitude higher than 400 ft. A box will appear with a warning and disclaimer. At the bottom is a check box next to the word agree. Check it and you are good to go.
  7. Pogimoto
    Okay well mine is set at 1600meters height and radius.. I should be fine right lol? But I'm not stupid to go past 400ft anyways.. I care more about the the radius distance..
  8. Pogimoto
    Who flies into a airport, that's nuts.. You have to be 3 miles radius away from a airport!
  9. general01
    Going to close to a airport is just insane the limits pogmo mentions are the default settings and can be adjusted to what ever you want
    Update I updated both my birds and the limits are fixed to 400 feet up so I bumped mine up to 500 feet
  10. Pogimoto
    I am in default settings, just height I changed to the same meter as default radius.
  11. Byroman
    Libby, Montana
    Pogimoto,
    Is your Vision still not allowing you above 200'?
  12. Pogimoto
    It's allowing me to past beyond 400ft no problem, it's the fpv I lose signal to after 300ft..
  13. general01
    Either time to upgrade the repeater or get a good antenna for it(unless the environment has a effect on it)
  14. Pogimoto
    Yeah I'm just going to upgrade.. I spoke with tony and I'm going to go ahead and order the stage 2 kit from him.
Similar Threads - Flight limit Forum Date
What version of DJI Go for iOS avoids NFZ and limited flight? Control (Go, Litchi, etc..) Nov 6, 2017
Flight alttitude and distance limit p3p Pro/Adv Discussion Sep 19, 2017
Phantom 4 limited flight speed after firmware downgrade Phantom 4 Help Sep 3, 2017
Limited flight distance after firmware update Phantom 4 Pro Help Jul 28, 2017
Standard Limited flight using IPod touch Phantom 3 Help Jul 28, 2017
