Looking for some data to share with those of you that would like to know the finer details of cold air flying our P3 in the winter months. Below is a list that may look like a lot but is mostly details. You can attach the .txt file in a PM. The .dat we will need to use dropbox.
What is needed:
1. The Flight air temps needs to be near or below 32 degrees/0 celsius.
2. Start with full charged battery with internal temps between 70-80 degrees / 20-26 celsius.
3. After launching and reaching flight altitude, the flight 1st needs to begin with at least a 5 second or longer Full Throttle pass. And then do a similar(same direction) 5 second or longer Full Throttle pass before landing.
4. Preferably a 5+ minute flight.
5. Must have 2.6.0 GO app, and 1.06.0040 firmware installed.
6. Need .txt flightlog(can be located in JI "FlightRecord" folder on device used), and .dat flightlog(located flight data area in GO app menu. Connect usb between pc & aircraft).
