Flashing yellow and green, still flies normal
Discussion in 'Phantom 2 Vision + Discussion' started by Frank Z, Nov 25, 2014.
  1. Frank Z
    Hello all. This is my first post since this is my first dilemma. Ive been flying my P2V+ since Aug. After the latest update I noticed my rear lights are flashing yellow / green. It acquires GPS with no problems and flies just fine. If need be it can find its way home. I understand the sequence of yellow / green if for warming up and it shouldn't fly. However it does fly and fly well. What do you think? Should I be concerned?
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    It looks like you might have the S2 switch set to IOC. Make sure both top switches are in the top position.
  3. noiseboy72
    Lincs, UK
    My IOC switch failed and it would not switch to any other mode. Maybe the same fault?
  4. Frank Z
    I will check that out on the next flight. Thanks
  5. Mako79
    Sydney Australia
    Dont check out on the next flight. Check it out while she is still gounded.
    Plug the RC or Phantom to the PC and check the switches if they have activity. All you need to do is flick up and down and you see the slider move.
    If the switch has failed and you happen to be stuck in IOC, unplug the other toggle (GPS/ATTI/FS) switch and swap them over to get you out of trouble.
  6. Frank Z
    Will do.
Similar Threads - Flashing yellow green Forum Date
Red green yellow lights keep flashing Pro/Adv Discussion Mar 13, 2017
Standard Removed gimble due to crash, now only get flashing red,green, and yellow light on one side Phantom 3 Help Jul 26, 2016
Professional HELP flashing red/yellow/green not connecting/ new p3 Phantom 3 Help Dec 25, 2015
IMU not cali & Yellow and Green Flashing lights Phantom 2 Vision + Discussion Jan 1, 2015
