Flashing Red and no start up
HI,
I've got my phantom one out after a bit of a break and having an issue! It goes through it's normal start up procedure, locatin GPS etc, but then just flashes red and won't start motors.
I've plugged it in and done an IMU calibration, and done a calibration on my remote (its an early model so not by plugging it in).
Any help welcomed, thanks
Hi, have you add components into your phantom like PMU ? I have this problem with the PMU installed. If you try connect again the battery you must wait 10 minutes between two test. I don't know more of this problem.
Good search.
How's the battery?
EDIT to add - here’s NazaM guide:
http://download.dji-innovations.com/downloads/nazam-v2/en/NAZA-M_Quick_Start_Guide_v1.26_en.pdf
Copied from LED error codes:
I am having the same issue. As soon a I turn on transmitter the yellow/red LED then changes to 4-5 flashing red with a space. This continues even when the transmitter is turned off. To the best of my knowledge I have not made any changes to the configuration and not crashed the unit to cause this problem. Any suggestions would be greatly appreciated.
cokersean20
