Flaky Wifi
Discussion in 'Phantom 2 Vision + Discussion' started by Meta4, Mar 5, 2015.
  1. Meta4
    Meta4 Moderator
    Staff Member
    The bird I'm flying lately works wel except the wifi is sometimes very hard to connect to.
    Sometimes it is easy and other times it's just not there.
    Today it took me 20 mins of shutting down and starting again to find the wifi but then it was fine for 4 flights.
    What should I be looking for under the hood to fix this up?
  2. flyNfrank
    Indy, USA
    I would start with the device being used to connect to the quad. What the quad is streaming to.
  3. Meta4
    Meta4 Moderator
    Staff Member
    The phone seems to be fine - no problems picking up loads of other wifi but the Phantom wifi seems to have an intermittent problem. My last Phantom was rock solid - always locked on pretty quickly.
  4. jumanoc
    2 tips about issue:
    1) If you fly near other WiFi networks known by your phone it will try to connect automatically to them. try far from there.
    2) If any people near your phantom, they can connect to to your phantom WiFi first than you (No Video in you device)
    3) Are you startin in correct order? TX, WiFi Extender and then Phantom. Wehn 2 green lights in extender, go to phone settings and connect to Phantom WiFi
  5. Meta4
    Meta4 Moderator
    Staff Member
    Yes .. no issues with other wifi nearby.
    It's just that half the time the phone tells me that the Phantom is out of range although it is 1 foot away and has been tirned on for 5 minutes.
    I've been flying for a year and switch things on in the correct order.
    There is an intermittent issue with the wifi and as I haven't had to work on the wifi before I was hoping someone that had could give me a few pointers as to what to look at or what might be the cause.
  6. happydays
    Warrenpoint, Ireland
    The wifi extender IS charged, isn't it?
  7. bbfpv
    Long Island, NY
    put your device in airplane mode, forget all networks, turn on wifi only, connect to bird.
  8. jumanoc
    OK, open the shell and verify tight connection WiFi wires and modules as well as Camera Wires.
Similar Threads - Flaky Wifi Forum Date
Little issues making pv2+ flaky Phantom 2 Vision + Help Jan 3, 2016
Flaky upgrade procedure! Should be done from TX Pro/Adv Discussion Sep 7, 2015
WiFi Module Repair Phantom 2 Vision + Discussion Wednesday at 11:43 PM
Moverio BT-200 WiFi connection problems Phantom 2 Vision + Help Jan 2, 2018
Standard Crash tore WiFi cable from connector Phantom 3 Help Dec 30, 2017
