Fixed Gimbal Settings Menu
Discussion in 'Phantom 2 Vision + Discussion' started by Kelvo1984, May 19, 2014.
  1. Kelvo1984
    Like many other people on here I could not access the gimbal settings in the assistant when the phantom was powered and plugged in. I recently reinstalled the gimbal firmware to hopefully fix the levelling issue and bam, got access to the menu page again. Give it a try. (Individual results may vary:) )
  2. c2xtreem
    How please you have the steps??
  3. Kelvo1984
    Plug phantom in, turn on, open app. Go to update, click on zen (something) and follow the prompts to install version (it will be the same version). Then power cycle the phantom and there it is.
  4. hambroski
    Thanks - I got to see the gimbal setting but unfortunately no means of resetting it. Mine is just off level and I think it is software related as it hangs flat when off. The battery came out mid flight which I think messed the gimbal settings up.
  5. MikesTooLz
    Miami, Florida
    how did the battery come out mid flight? the battery is hard as heck to get out.
  6. Skynet1
    +1
    I need to use a pair of vice grips to get the battery out, and your battery came out in mid flight :shock:
Similar Threads - Fixed Gimbal Settings Forum Date
Fixed gimbal Phantom 2 Vision + Discussion Oct 11, 2017
gimbal noise problem fixed :-) Phantom 4 Pro Help Sep 16, 2017
Crashed and fixed gimbal, camera issues. Please help. Pro/Adv Discussion Feb 28, 2016
Phantom 3 Standard Camera Gimbal Misalignment and Motor Overload FIXED! Standard Nov 6, 2015
Fixed my gimbal vibration Pro/Adv Discussion Oct 29, 2015
