Fit air pad air 2 into original phantom 4 case ?
Is someone tried to cut off the case to be able to insert an ipad air 2 into the original phantom 4 case ? i've search here and on google, with no result !? i think it is impossible that i am the only one thinking of doing it :)
no you are not the only one trying to find a way , i wish they considered that when designing the case because it would have been great if you could fit the ipad in there instead of carrying it separately , perhaps they should have left a bit of space in the lid area to slide it in
I think if you cut the foam it will fit but i don't want to be the first one to try it
I all most started cutting mine over the weekend. Looking at the case again, there is just no room. The only spot that might work is right behind the TX area, but you would need to cut into the hinge.
BoguSlav
