  1. KevMo Photog
    While flying today had a prop warning come up. I forget now exactly what it said. But I'm guessing maybe a little bit of wear on the plastic fittings is causing a bit of vibration in the motors. Landed and changed battery and did not have the warning on 2nd flight. Has anyone had this yet and should I go ahead and change props now? Still on my original set after 2 months plus. Prob flown 120 flights maybe.
  2. Phantomix
    Weston, MA
    dont change them unless you see any damage at all, and i have seen a few reports of this
    KevMo Photog likes this.
  3. KevMo Photog
    Ok great Phantomix. Wasn't sure if it might be hard on motors if a prop was a tad sloppy in the fittings. They seem fine when I put them on still though.
  4. Phantomix
    Weston, MA
    I would very carefully inspect the motors and propellers, to make sure that nothing is wrong. Better to find a crack before flight, than realizing it after it crashes.
  5. suck it up
    check and make sure the screws are tight at the engines and prop holders....
  6. KevMo Photog
    No problems there. Theyre all snug. Inspected all props too. They look flawless inside hub and everywhere else. Might have just been a freaky glitch.
Similar Threads - prop problem warning Forum Date
propellers guard problem Phantom 4 Pro Discussion Feb 7, 2017
New Props for V3.0 for use on earier version any problem Phantom 2 Vision + Discussion Oct 13, 2016
Lowepro drone bag problems - bent props Pro/Adv Discussion Oct 9, 2016
phantom 1 prop motor problem Phantom 1 Help Aug 22, 2016
Lose a prop? No problem General Discussion Jan 8, 2016
