So weather here in the far northwest been so bad that I haven't done a thing with new P4 except unpack it. Indoors today and did the firmware update on the aircraft with my iMac. Went well. So just hooked everything up and noticed the following:
1. With USB cable supplied, the small end had to be forced into the outlet on my iPad Mini 4. (It fits fine in the aircraft.) And when I got it inserted, nothing worked. Grabbed the charging cord for the iPad and everything started working and I got through activation and actually did some time on the simulator.
Did I make a bad assumption that the supplied cable would fit the iPad?
Is it ok to use the Apple cable ?
2. Down in the "About" section where the versions are noted, aircraft was right on with .602, controller showed 1.6.0. I thought I saw elsewhere that it was supposed to be 1.8.0. Could not find anywhere where it said to update the controller. Any problems here?
Thanks for all the help you guys provide.
David
David
