So after about 10 or so uneventful flights I crashed my p3a in the backyard. I got to close to a tree branch and clipped it with a prop. I was probably about 10 ft high and the aircraft flipped upside down and fell to the ground. Landed on the top. The only damage I can visibly see is one part of the frame is out of alignment, everything else appeared to be OK. I checked it over pretty good and did an imu calibration and flew it again. All seems to be OK that I can tell. Any suggestions or anything specific I should check. Is it worth taking the frame apart to realign/clip it back in place? It is pretty minor deviation in one spot located about midway on one of the arms. Thanks.
