first incident
Discussion in 'Phantom 2 Vision + Discussion' started by dutch, Dec 15, 2014.
  1. dutch
    Upstate NY
    in a rush on lunch time to get footage of the ice we have had accumulate in
    the trees around here, and i clipped the top of a tree and the phantom v.3
    fell down thru some branches, i could retrieve it easily as it was only 100' away
    from me.
    i broke a prop, so i replace them all and rebooted, but got no satellite indicators
    on my phone. (the phantom blinked green like normal)
    the gimbal and camera worked, i could tilt the gimbal and view the camera on
    my phone.
    inside i did a more thourough inspection, and found one of the wiring plugs going
    into the top of the camera/gimbel assembly had a wire pulled out, and another one
    loose. so it looks like i am going to get to know my phantom intimately, sooner
    instead of later.
    are these wires going to be able to go back into the connector ok?
    2ndly, i noticed that i have 2 wires coming down the legs of my phantom, the compass from
    what i read. after this incident i noticed one leg looks normal, but the other one i am not sure
    if it's normal, but all i see is the end of a wire, with nothing attached., sort of tucked inside the
    leg. my hunch is i am missing another compass component? which will be impossible to find
    since everything in/under and around the tree is encased in snow and ice!
    here's a pic of the loose wire on top of the gimbal,
    any thoughts on repairing myself?
    i did not start the motors, for fear i had no satellite signal, even though i had normal blinking
    green lights.
    i have a picture of where the wire is pulled, but not of the leg. can post later
  2. davisual
    Yup I did the same. I just ordered the wires and replaced. Easy fix.
  3. dutch
    Upstate NY
  4. Meta4
    Meta4 Moderator
    Staff Member
    It might help to use tweezers to replace the grey gimbal cables.
    The other wire you mention if your antenna and quite normal
  5. BlackTracer
    Winter Park, FL USA
    The best part for me was you running towards it at the end. LOL but not really. **** those treetops to hell. I hope you can fix it.
  6. Prylar Bek
    Wow. Doesn't take much to bring them down!
  7. RichWest
    Houston, Texas
    Sorry for your crash...lesson learned right. I really like the video perspective of snow and trees. I think most have been caught in a video running to a downed Phantom...;)
    Just had a similar hit(s) over thanksgiving, tree jumped up to my altitude and took me out. Like you, I got caught up in doing the video and forgot the surroundings. Minor damage to the shell and two props destroyed, dusted off and good to go. Here's to your next crash being less painful.
    Buy the replacement wire set and change it out.
  8. dutch
    Upstate NY
    wire set ordered, not too bad, really.
    i did get lost in the video, but i was watching the phantom and thought i had goosed it
    to get up over and miscalculated... another rookie mistake.
    i have no instincts to shut the thing down though... it shut itself down.
    i just hope the lack of satellite strength showing on my phone is from those wires,,
    am i safe to say that without the app running on the phone, with the proper indicators
    with the lights, it's still safe to fly?
    maybe it's time for atti mode..........
  9. sdtrojan
    San Diego, CA
    I was wondering if you were flying FPV, but I guess this was a Vision and you were dual tasking between the phone and the copter. I know if I were flying ANYWHERE near trees I would have my eyeballs on the copter.
  10. dutch
    Upstate NY
    i have not flown in FPV yet,
    but, as i watched it go over towards the big pine tree,
    then compared to watching it on video, it's amazing at how
    bad my depth perception is watching the phantom, either live or
    thru the app. my old eyes are getting bad i guess!
    i really thought i was higher than i was.
  11. rickasaurus
    Sydney, Australia
    I guess it is a timely lesson to all of us rookies - give yourself more altitude than you think you need. The angle of observation from ground to bird can be very deceiving.
    Rick
  12. StangLuvr
    Portland, TN
    I use to race motorcycles in my local harescramble series. Those dang trees will jump out and get you when you least expect it. I am glad your phantom is not broken bad. I just flew my P2V+ for the 1st time today. Flew my P1 a lot and was comfortable. Now with the P2V+ i am nervous.
    I bet you were running a sub 4 second 40 yard dash there at the end.......Looked just like me though the 1st time I downed my P1. I was Usain Bolt!!!
  13. dutch
    Upstate NY
    oh god no, too old, and with these new hips i'm not even supposed to run!
    lesson learned, and hopefully this new wire/cable is all the damage, but i did break a prop tip off..
    and my compass looked in tact, and the other wire is the antenna... all good to go i hope!
  14. hey_moe
    Hampton, Virginia
    Don't think you are the lone ranger on the crash. I did the very same thing. No video but ended up with two busted blades. I joined a RC Club and fly above the trees now and in fields until I get the hang of it >>>>> https://www.youtube.com/watch?v=2dw29C1Nx6w
  15. dutch
    Upstate NY
    thanks for that idea, i did take the gimball off it's rubber isolators,
    and took the plug out and stuck the wires back into the plug/connector
    and attempted to reconnect into the gimbal, i thought it was good and
    turned everything back on but still have no phantom battery indicator or satellite
    indicator in my app on the phone. all else displays good, wifi indicator, tx battery,
    and the SD card. camera/gimball works well, phantom fires up, blinking green,
    with no props on in the house it blinked green like normal, and motors worked
    as expected.
  16. jmlooper
    Man that's for sure. great video, that pine tree ***** will bring you down everytime. Hehe...that's why they use them for xmas tree toppers.
Similar Threads - incident Forum Date
Another Strange Incident Phantom 4 Discussion Jul 3, 2017
Very strange incident with my P4... What happened? Phantom 4 Discussion Jun 24, 2017
Possible $1,437 Fine for Padres Drone Incident Rules and Regulations May 25, 2017
Drones called “Low Orbiting Incident Satellites,” or L.O.I.S. News May 24, 2017
Odd No Fly Zone incident with Police Rules and Regulations Dec 14, 2016
