First flight
Discussion in 'Phantom 2 Vision + Discussion' started by Iabove, Dec 5, 2014.
  1. Iabove
    I finally got to fly today after all the rain
    I notice that maybe 15 feet off the ground hover was ok but it would slowly drift away some times no wind btw
    Any advice maybe need to do the advance calibration again ? I don't know
    I had like 8 satellite connections
    Thanks guys for great advice from experts
  2. paulajayne
    Bocking - England
    With a GPS lock it should stay within circa 2.5 metres horizontal and circa 0.8 metres vertical with no input.
    Is it outside these limits?
    Did you maintain a GPS lock?
  3. Iabove
    Can you say that in feet or inch
    And by gps lock when I did phantom dance it was blinking green only then when I start motor start flying it was one green blink one red blink
  4. Iabove
    Should I recalibrate remote I mean I did it before and it all center green when it was drifting slow one way I didn't wait to see how far it would go drifting
  5. msinger
    Approved Vendor
    Harrisburg, PA (US)
    This means you only had 6 satellites. The lights will blink green only if you have 6+ satellites.
    Was the S1 switch in the top position? If it was in the middle position, you were in ATT mode. That could explain the slow drifting.
  6. jerrymac12000
    Colorado Springs, CO
    Vertical .8 meters equals 2.7 feet
    Horizontal 2.5 meters equals about 8.5 feet.
  7. Meta4
    Meta4 Moderator
    Staff Member
    How far was it drifting?
    A little is normal but it's hard to comment when we don't know what yours is doing.
    If you have a P2+ you should be able to see the number of sats in the app.
  8. Iabove
    Wait maybe because I was recording after I took off
    There was power lines about 50-80feet from my hovering point and home
    I just wanted to get a feel for it maybe 10min flight
    All the switches was all up
    I have put my phantom in naza mode but my switch was in GPS mode
  9. Iabove
    less than this
    I am on PV+
    But I didn't look at te sat when it was in the air I kinda had to a feel for the control
  10. Iabove
    I'm going to fly in a hour or so
  11. Iabove
    Another thing how can I make sure where my home lock is where will it show me on my phone
    And let's say its wrong can I manually put the fix point of home lock
    By the way I'm using a iphone 4 not 4s
    Seem to be ok but what the hell would I know is this the only thing I have around that I can use at the moment
    Dji never got back to me on what might be some issues I might have with using iphone 4
    Thanks in advance
  12. aartsf
    Home point can be recognised on your phone as bying the centre of the radar image on your phone app.
    Home point is initional set at the place where you start up your bird when you allow it some time (few seconds) after it has lock sufficient satelates. Afterwarts (when flying) you can re-define homepoint manually; see manual.
    Recently (after latest Dji app udate) there is also the possibility to use a dynamic home point. The phone with the app will than be your homepoint, which will move together with the movement of you phone. You find this as a possibility you can select within the setting of the app.
    Regards FA
  13. Iabove
    Thanks alot
  14. Jstic
    Not sure about others, but I find that the more satellites I have, the less drifting(no wind). 6-8 satellites is where I get moderate drifting, 10 and above and the quad is almost rock still.
  15. aartsf
    That will be the case for everyone. The more satelites the more presice the bird will know its exact position and the better it will be able to maintain its position.
Similar Threads - flight Forum Date
How is about the drone flights in UK ? General Discussion Sunday at 7:13 AM
FLIGHT ADVISORY GPS INTERFERENCE TESTING General Discussion Saturday at 1:22 PM
Question about flight outside of national forest Rules and Regulations Saturday at 12:39 AM
Anyone know if there is any program/app that let's me pre plan a flight with my DJI P3SE Phantom SE Friday at 8:47 PM
dji go 4 flight list (flight log) dates Phantom 4 Pro Help Friday at 8:58 AM
