First flight with my P3A !! RTH failed?? Good video quality??
Discussion in 'Pro/Adv Discussion' started by Holrits, Feb 26, 2016.
  1. Holrits
    Hi guys I just tried my P3A for the first time!
    And of couse i tested the RTH feature, but i found it strange that when I pressed the button on the RC, the after 5 sec the Drone just started landing, it was about 10 meters from saved home point, but it didnt do anything else than just start landing, so i was needed to cancel the RTH so it didnt land on a roof.
    I tried it 3 times, but same result.
    Is this normal or shouldnt it be more close to home? I had FULL GPS signal 15+ sattelites
    I managed to get the log out of the drone (yay!) but we/I use it to see what happended?
    Also what do you think of the camera video quality is it good? i read some saying some of the cameras was out of focus. Everything here is recorded with the settings set to "auto".
    (seems like it got a little "redish" after i changed it in Movie Maker)
    And also what about the sound, how do i get that to work when recording?
    Best Regards Nicolai!
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    That's as designed. Your Phantom will land at its current location when not more than 20m from the home point.
    Holrits likes this.
  3. Holrits
    Okay, so if not more than 20m it will just land, but if im more than 20, it will land at the "start" position / home point? :)
    Thanks for the fast reply!
  4. WetDog
  5. msinger
    Approved Vendor
    Harrisburg, PA (US)
    That's correct.
  6. Holrits
    Aldready did bro.
    InkyRisk likes this.
  7. Holrits
    Do you know if its possible to get sound on the video :)?
  8. msinger
    Approved Vendor
    Harrisburg, PA (US)
    The Phantom 3 does not record sound. However, you can add a soundtrack afterwards via some kind of video editor.
  9. Holrits
    hm im just wondering yesterday i tried to livestream from it at my home office, and there was sound on it :O just thought it was the Phantom that recorded it
  10. msinger
    Approved Vendor
    Harrisburg, PA (US)
    It was the sound recorded by your mobile device. The Phantom has no microphone on board.
  11. Holrits
    Aha! smart, thanks for the help :D :D !!!
  12. Dirty Bird
    Glen Burnie, MD - USA
    Normal. If you are <20m from Home Point it just lands where it is. Go out a few hundred feet & try again.
  13. Holrits
    It was just so close to buildings so i was afraid of flying to far away :p
  14. Dirty Bird
    I noticed you were flying right above the rooftop & trees. I suggest adding a bit of altitude to be safe until you get the hang of things. It is easy at a distance to misjudge. Also be sure to set your RTH altitude in the app. You want to make sure it is well above any obstacles you might encounter along the way. It's best to err on the high side! Also remember the RTH setting is in meters only.
  15. jonebk12
    Regarding the sound, it would be mostly useless to have it record audio. I had a Syma (before she got lost in a tree) which recorded sound. The sound of the rotors drowned out everything and got pretty annoying to listen to. That little bird was a lot quieter than a Phantom.
  16. offthefront
    Northeast Florida
    Make sure you settle RTH altitude @ a height above any obstacles between the aircraft and home ...
  17. msinger
    Approved Vendor
    Harrisburg, PA (US)
    And, don't forget to manually reset your home point if you move away from the previously marked home point. You don't want your Phantom to try returning to the old home point when you're right next to it after it lands.
  18. Holrits
    Yes, i have set The RTH attitude to 30 m :)
  19. Holrits
    Thats true :) just wanted to hear it, and see if it was possible :)
  20. Holrits
    Another thing, i tried the "follow me" feature, but when i tried to Press "apply" it kept saying, "not enough gps signal", is this my iPad gps signal? Still dont understand why it shouldnt have enough signal, standing outsite facing the sky :(
    And also, i a cannot enable The IOC in The app? Its "grayed out"
Similar Threads - flight P3A RTH Forum Date
P3A Midflight disconnect - drone did not RTH General Discussion May 8, 2016
Advanced P3A Fly Away w/Flight Log Link Phantom 3 Help Apr 13, 2017
P3A compass error after flight Pro/Adv Discussion Dec 31, 2016
P3A controller to pc for 3rd party flight sim? Pro/Adv Discussion Dec 28, 2016
How long flight plans with Litchi and P3A do you plan? Pro/Adv Discussion Oct 20, 2016
