First flight after update.
Discussion in 'Phantom 2 Vision + Discussion' started by Forester, Nov 30, 2014.
  1. Forester
    Flew for the first time today after updates. Didn't feel good about it being somewhat unstable. Took it home to check it with the assistant software, and it would not recognize the PV+. Don't understand, it recognized it when I just upgraded but now it won't. Hooked up my PV2 which I also upgraded and it recognized it just fine when I hooked up the PV+ it said to plug into controller. Tried booting both PV+ and software up numerous time with now results. Getting frustrated with DJI. Don't trust my Phantoms like I use too.
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    When using the Assistant, you must plug the mini USB cable into the Phantom on the opposite side of the battery (under the white flap). It sounds like you're saying you plugged it into the remote control. That will not work.
  3. Forester
    Nope. This is my third Phantom. Its plugged in correctly
  4. aartsf
    Maybe one assistant-application can only accomodate one type of pantom. Therefor you may need the assistant sw 2 times on you Pc; one for each type of bird?
    Just a thought.
  5. Forester
    It worked fine with both phantoms. It's being shipped back to Dronefly in the morning. Really disappointed. First flight although I bought it end of September. Our weather been wet as always and couldn't fly till now. Off warranty now, so it will be $99.00 min. Getting a little frustrated. Thought maybe of selling what I have and starting over with another brand or even the new inspire 1. Thoughts?
  6. brorex
    You could try Uninstalling the software and drivers and trying to reinstall see if that works.
Similar Threads - flight update Forum Date
Drone Harmony Update 0.5: 6 new plans, Flight Logs, UI Improvements Control (Go, Litchi, etc..) Today at 10:58 AM
Uncontrollable flight after latest update Phantom 4 Help Sunday at 10:46 PM
Limited flight distance after firmware update Phantom 4 Pro Help Jul 28, 2017
Test flight DJI GO 3.1.3 update Standard/4k Discussion Feb 14, 2017
Updated firmware to 1.8 for third test flight , first time over water Standard/4k Discussion Jan 23, 2017
