First antenna mod was great, 2nd mod wasn't - seeking advice.
WI
Thanks for the input from some of you... I will figure it out.
Good lord your controller looks like a glorious Frankenstein built for range... When you figure it all out I hope to build one like it!
Looks like you would have been better off with an Advanced version?
You should probably be using a LiPo Battery instead of a usb power bank. Ill find a link for you but a 3S Lipo battery with a 12v power output would definitely work better.
12V dual lead battery 3000mah with charger (this is made specifically to power 2.4/5.8 sunhans amps, not sure about the additional 2.4 amp)
Also, hopefully you use a neckstrap lanyard lol
The problem is you you may have tried to hard
well he already bought it and is trying to find out the problem, dont think your answer is helping him much
Reactions: kmag
