Firmware upgrade results.
Discussion in 'Pro/Adv Discussion' started by fin032, Apr 7, 2016.
  1. fin032
    Fife, Scotland
    Just completed the latest update on the P3P and have the result below on the card. If you have a look around the middle you will see this. It also has Upgrading success at the top. Anything to worry about?
    ========== 2014.01.01 00:00:12 remo-con disconnect======
    Packet: P3X_FW_V01.06.0040.bin
    Upgrading ...
    Result: Corrupted.
    Firmware bin file is corrupted, download it again from the DJI offical website.
    Full result file.
    ========== 2015.10.30 09:50:45 =====================
    Packet: P3X_FW_V01.04.0010.bin
    Upgrading ...
    Result: Success.
    ========== 2014.01.01 00:00:13 remo-con disconnect======
    Result: Abort.
    The firmware on the SD card is identical to or older than the current firmware on the aircraft.
    ========== 2015.10.30 10:00:03 =====================
    Result: Abort.
    Packet: P3X_FW_V01.05.0030.bin
    Upgrading ...
    Result: Success.
    ========== 2015.11.26 23:21:03 =====================
    Result: Abort.
    Upgrading ...
    Result: Corrupted.
    Upgrading ...
    Upgrading ...
    Result: Success.
    ========== 2016.01.14 11:14:45 =====================
    Result: Abort.
    ========== 2014.01.01 00:00:14 remo-con disconnect======
    Result: Abort.
    Upgrading ...
    Result: Success.
    Result: Abort.
    Packet: P3X_FW_V01.07.0060.bin
    Upgrading ...
    Result: Success.
    Result: Abort.
    Result: Abort.
    Packet: P3X_FW_V01.08.0080.bin
    Upgrading ...
    Result: Success.
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Looks good. It's showing 1.8 installed successfully. You can double-check the installed firmware versions in the About section of DJI GO.
  3. fin032
    Fife, Scotland
    Cheers. Have you any idea what's with the corrupt text in the middle of the text results?
    Upgrading ...
    Result: Corrupted.
  4. alokbhargava
    San Francisco, CA
    I am really not clear what happened during
    Result: Abort.
    Upgrading ...
    Result: Success.
    It looks you had downgraded and upgraded again but those steps are missing. A big question mark. But no need to worry now as you have the latest already successfully installed.
  5. Dirby
    Dothan Al
    what does this new firmware do?
  6. msinger
    Approved Vendor
    Harrisburg, PA (US)
    You can see the changes in the release notes here.
  7. Canada_Drone45
    It limits your distance makes the it fly like the phantom 4 like crap ...:)
  8. Phantazmk
    Looks identical to mine. I updated from 1.6. Same log as yours for 1.8. Yours looks good
  9. fin032
    Fife, Scotland
    Good to know
Similar Threads - Firmware upgrade results Forum Date
Upgraded firmware Last week and now constant strong interference Phantom 4 Help Dec 19, 2017
CS Firmware upgrade is available CrystalSky Monitors Dec 15, 2017
Upgrade Cam/Gimbal on P3A - Downgrade To P3P To v.01.07.00 Firmware Pro/Adv Discussion Dec 9, 2017
How to upgrade firmware on a phantom 3 pro without a camera or gimbal installed Pro/Adv Discussion Dec 9, 2017
Question about firmware upgrade Pro/Adv Discussion Nov 20, 2017
