Professional Firmware Upgrade Issues
Discussion in 'Phantom 3 Help' started by David Gaunt, Sep 24, 2016.
  1. David Gaunt
    Hi, I have tried everything to upgrade to the latest firmware without success. I have formatted the SD card and done all that is asked but it won't take. So frustrated. Any help would be appreciated.
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Try following these instructions to update the firmware.
    Also, I have a few questions for you:
    1) Do you have a Phantom 3 Professional?
    2) Is this Phantom brand new out of the box?
    3) If it's not new, why are you updating the firmware?
    4) If it's not new, has it ever been crashed, dropped, or damaged in some other way?
  3. tcope
    Salt Lake City, UT
    99.99999999% of the time the error in not uncompressing the downloaded file and using the bin or not copying the bin file to the root folder of the SD card.
  4. David Gaunt
    Hi, yes its a phantom 3 professional
    I bought the Drone about 8 months ago used it once and it has been sitting in the box since
    when I turned it all on a message came up on the DJI Go app telling me to update the firmware of both the controller and the aircraft
    It has never been damaged at all in anyway
    I have been online with the DJI support team for hours and they were of no help. Looks like it could be one for throwing away :)
  5. David Gaunt
    I showed the DJI online support the bin file I was downloading and they never indicated it was incorrect to me. I formatted the SD card a number of times, have tried 3 different brands of SD card and nothing, so frustrating. The file is below.
    P3X_FW_V01.09.0060-13.bin
  6. David Gaunt
    I FINALLY got it to upload the file. I renamed the file without the -13 and it did its thing. Thanks so much for the direction to the installation guide, which tells you to ensure there are no numbers attached at the end. :)
  7. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Great news! Thank you for following up with your fix.
Similar Threads - Firmware Upgrade Issues Forum Date
Firmware Upgrade Issues Phantom 4 Discussion Nov 8, 2016
[Help] Firmware Upgrade Issues. Signal Lost & Props Couldn't be Started. Standard/4k Discussion Oct 17, 2016
P3S Range issues after firmware upgrade Standard/4k Discussion Apr 7, 2016
Professional Please help - Firmware upgrade issues :( Phantom 3 Help Oct 12, 2015
Gimval issues after firmware upgrade Firmware Jun 29, 2015
