Firmware upgrade help
Discussion in 'Pro/Adv Discussion' started by Hecto, Apr 8, 2016.
  1. Hecto
    Hello everyone I need some help with my p3a. I am a beginner with only about 4 hours air time with no problems.I currently use firmware p3a1.5.30+, RC 1.5.70 and the app is 2.7.1 my question is should I upgrade to 1.8 and if so do I have to upgrade to 1.7 first? Thanks
  2. alokbhargava
    San Francisco, CA
    Your current FW on aircraft is known to have issues, better upgrade to at least 1.6.
    In case you want to upgrade to the latest 1.8, you can do it directly.
  3. Hecto
    Chi doesn't offer 1.6 anymore, I may try my luck with 1.8
  4. Hecto
    Dji I mean
  5. Tony Cowan
    You may hear some say don't upgrade. Every software has hidden bugs. So best to fix it and upgrade. Go to dji.com on your computer. Download file and copy to your sd card. Out sd card in drone and turn on. 4 beeps means it's updating. After it's done it will have a long beep followed by 2 beeps. Put sd card back in computer and look at text file. I will tell you if update was of was not successful. Good luck.
    hjklaassen likes this.
  6. hjklaassen
    Manitoba, Canada
    I upgraded to 1.8 this afternoon and had no problems when I took a flight. Everything worked as it had before. But what I liked was that the camera tilting to one side has been cured. I was on 1.7 and I had the tilt and now it's gone.
    In conclusion - I would not hesitate. I also have the Phantom 3 Advanced.
  7. msinger
    Approved Vendor
    Harrisburg, PA (US)
    You can find a list of all P3A firmware versions here.
Similar Threads - Firmware upgrade help Forum Date
Firmware won't upgrade . Help please Phantom 4 Help Jul 14, 2017
Firmware upgrade P4 help Phantom 4 Help Mar 24, 2017
Help - error beeping, but not firmware upgrade Pro/Adv Discussion Dec 13, 2016
P3 Firmware Need Help Correct Steps To Upgrade Firmware Properly Firmware Dec 9, 2016
[Help] Firmware Upgrade Issues. Signal Lost & Props Couldn't be Started. Standard/4k Discussion Oct 17, 2016
