So I'm getting my P3P tomorrow. How would I check the current firmware if it needs updating? I'm coming from a P2 where you plug the P2 to your PC you can see it through the Phantom software on the PC. I will not have an SD card once I receive it.
The DJI GO app will prompt you to install the update if one is available. If you decide to update, I have detailed firmware installation instructions here.How would I check the current firmware if it needs updating?
If you are buying it new, it will come with a micro SD card.So I'm getting my P3P tomorrow. How would I check the current firmware if it needs updating? I'm coming from a P2 where you plug the P2 to your PC you can see it through the Phantom software on the PC. I will not have an SD card once I receive it.
Yes and yes. If you need detailed instructions, see this thread.If yes, do I need to put v1.8.80 on an sd card and insert it then insert the batter then turn the P3 on?
