Firmware failure
I recently purchased a used Phantom 3 Professional without a gimbal and camera. It performed just fine. I then tried to add a used 4k camera/gimbal to the drone and was directed to update the firmware. I was unable to update the firmare via sd card and must have done something to the software because the drone now will not work. Is there a way to update the firware without a gimbal/camera attached to the drone?
Thanks,
westel
Normally no, you can't properly update firmware with the camera/gimbal removed.
Question - did you use a P3P 4K camera, or did you use a 4K camera from a P34K? I ask because it has been frequently asked here if a P34K camera can be used on a P3P. A few people have had issues when they tried to use one before finding out that it won't work.
Reactions: JoBe
cgarner1
