- Joined
- Feb 15, 2017
- Messages
- 30
- Reaction score
- 14
- Age
- 38
see the thing about these OEM 9450 props.... they are very strong able to smack right into a tree or street sign or fall on the ground out of the air and still be durable enough to takeoff 1 sec later......I've heard horror stories about these brittle " Carbon Fiber" props definitely interested but also a lot of fear.....next time share a quick pikAnd i absolutely in love them. The drone is more responsive and faster with crisp movements. I was scared to do it at first after reading all the horror stories. Seem the cheap knockoffs have issues
My fastest time was with a set of CF props, just saying. And that was not because of a tail wind that day. Had some higher tail winds with the stock props, but my max forward speed was with a set of DJI reinforced CF props. 38.25 mph P3S. Unless you've really tried a set, side by side on the same equipment?I don't know about more responsive but it definitely won't be faster, it's just not possible. Given the issues and lack of advantages your probably best advised to buy a spare drone when you go the CF route.
On a static test rig, prop driven at a constant RPM and thrust measured I would not be suprised to see greater thrust generated by the carbon reinforced model. It would likely be negligible however as the DJI carbon reinforced props still exhibit considerable flex. Carbon reinforced has condlsiderably less strength than true resin impregnated carbon fibre woven material.My fastest time was with a set of CF props, just saying. And that was not because of a tail wind that day. Had some higher tail winds with the stock props, but my max forward speed was with a set of DJI reinforced CF props. 38.25 mph P3S. Unless you've really tried a set, side by side on the same equipment?
I have the same ones from DJI, like the performance enhancement but seem to notice camera footage is not as smooth. A bit of shaking especially if the camera is pointed completely horizontal. Have you had any similar occurrence.Im using the carbon Fiber blades, original From dji for two months...
Its not lighter than the normal blades, it have the same weight because It have the core in metal...
I like It just for being reinforced...
My original blades, in one month, had some dents...
The carbon Fiber blades, still as New...
Sent from my XT1097 using PhantomPilots mobile app
