Well, whatever you do do not insert the micro sd card at a particular angle because mine is jammed inside my brand new Phantom 4. I mean it felt right going in and when I went for that "click" push it just jammed. I had just got everything out of the box and charged up to begin the update process. Went to insert the sd card and did so at an angle that simply jammed it. I also happened to begin the update process with the jammed card. So two questions if you please.
1.) Any recommendations on getting this sd card out of the P4?
2.) If the sd card was somehow ajar inside the P4 is it possible the update did not perform properly?
