FCC Mode Question
Discussion in 'Phantom 2 Discussion' started by stringfellow1946, Aug 10, 2014.
  1. stringfellow1946
    Hi
    I’m new to the board & this might appear to be a bit of a dumb question.
    I have a Phantom 2 with a Zenmuse H3 3D GoPro Gimbal & GoPro 3+.
    I have been trying to get the controller in FCC mode to extend the range, I’ve turned the bottom screw all the way to the right (as the videos say) but the controller does NOT beep & the LED light is red, not green.
    My question is having turned the bottom adjuster all the ways to the right will it now be in FCC Mod? & will the range now be extended?
    As I have no way of confirming it, can anyone tell me the answer please.
    I’ve seen in other posts on here that the Phantom 2 controller dose not beep anyway, so I’m more than a bit confused.
  2. 4wd
    4wd
    North York Moors
    It probably is in FCC. Plug it in the assistant software and it will show you, if still showing on CE change it there too.
  3. ElGuano
    CE/FCC mode is only a feature of the 5.8ghz transmitter (FC40, P2V, P2V+), not the 2.4ghz P2. That bottom pot has been in the Phantom controllers from the very beginning, but it seems it has never done anything on them...
  4. stringfellow1946
    Ok Thanks ELGuano That explains things, will I have affected anything by turning the bottom pot all the way to the right?
  5. stringfellow1946
    Hi 4wd its not shown in the software for the 2.4gig controller. But ELGuano has explained things.
  6. ElGuano
    Not that I'm aware of, but again that's cause nobody knows what (if anything) it does!
  7. myeyecu
    I thought it controlled the chick magnet.
  8. OI Photography
    Clarksville, TN
    That's what ElGuano is saying, it's obviously non-functional :lol:
Similar Threads - FCC Mode Question Forum Date
Dumb Question???? Where do I check for FCC/CE Mode? Phantom 2 Vision + Discussion May 4, 2015
FCC mode Question?? Phantom 2 Vision + Discussion Nov 27, 2014
FCC Mode Question Phantom 2 Vision + Discussion May 18, 2014
Mavid Dji.configs FCC mode working with P4P? Phantom 4 Pro Discussion Aug 3, 2017
CE to FCC mode? Phantom 4 Pro Discussion Jan 22, 2017
