FC40 Pilots: Check your transmitter range!
Discussion in 'Phantom FC40 Discussion' started by FatKevinSmith, Jan 24, 2014.
  1. FatKevinSmith
    http://www.youtube.com/watch?v=gpG_l9wAK_0
    So according to the above link, if you turn your transmitter on and hear one beep, you are actually in CE mode and your transmitter is limited to 300 meters. A turn of a screw on the back should put you in FCC mode (For those in the US, anyway) which boosts the power output to 500 meters.
    Now, this video is based on the Phantom 2 Vision controller but they claim the FC40 controller does the same thing. Can anyone do a quick test on their controller to see if:
    A) Your controller is set to 300M or 500M by default (based on the beeps), and
    B) If you are in fact defaulted to 300M, does the screw adjustment work?
    Thanks!
    P.S., I know this is all documented quite well in the online manual. Just curious if CE is factory default.
  2. jamerd
    The transmitter is set by default to CE i had to crack open my case to get to the pot then it was only a matter of about half turn recheck confirmed it was 2 beeps FCC hope this answer that question.
    Dennis
  3. chrisliles
    Hertfordshire, U.K.
    Mine was on the single beep when new, Turned the lower screw on back of controller half a turn clockwise and now get 2 beeps when powering on, Not been brave enough to try flying further away but hope the extra signal strength will prevent any problems.
  4. Daletri
    I was able to change my transmitter settings the assistant software from CE to FCC and now when I turn the transmitter on it does beep twice.
Similar Threads - FC40 Pilots Check Forum Date
FC40 flips on takeoff. Seems gyro reversed? Phantom FC40 Help Thursday at 8:28 PM
phantom fc40 help needed please ? Phantom FC40 Help Thursday at 2:07 PM
phantom fc40 manual Phantom FC40 Help Aug 6, 2017
dji phantom fc40 please help Phantom FC40 Help Aug 6, 2017
Standard P3 FC40 video disappeared Phantom 3 Help Jul 2, 2017
