FC40 not connecting to controller
Hello!
I recently purchased a (used) FC40 without battery, so i had to buy a new one.
The connectors inside the aircraft needed soldering because some of the insulation on one of the wires to the battery was gone.
I tested the aircraft with a battery, it connected successfully to the controller, and i managed to start the propellers before the remote LED on the front of the FC40 started to blink. I guess it was because lack of GPS-calibration. But i found out the the aircraft was fully working.
So i changed the battery wire, put the drone back together, but when i turned on the RC and then the aircraft, the remote LED only blink orange.
I have tried to pair it with the aircraft over and over, but nothing happens.
The red/orange blinking light inside the drone lights up red when the RC is not turned on, and blink orange and red when i press the button to pair it. And of corse the LED turns off when i turn on the RC.
In the manual it says when the remote LED blink orange, the transmitter signal is lost.
Can someone help!?
-Freddy.
It's not a new transmitter. Just suddenly stopped working.
But the problem is solved. Somewhere on Youtube someone said to change the receiver type from PPM to D-Bus. This did not work either. But last night, when i tried to pair the RC again, i changed back to D-Bus. Suddenly the sliders on the stick calibration etc. was moving.
Glad you were able to get things solved:)
I just installed the mini iosd with the NAZA pmu v2 now my pc can't find the controller. Any ideas??
Pauos31
