FC200 ver 1.3
Discussion in 'Phantom 2 Vision + Discussion' started by DrJoe, Feb 28, 2015.
  1. DrJoe
    Hey guys, I've been absent a while. I have not upgraded my P2V+ camera to the new firmware yet. I've searched the forums, but no real useful info on what this upgrade does.
    I see I missed the 3.10 upgrade that got taken down. I've been burned on updates before, so I want to be sure before I download the 1.3 FC200 update.
    I am running Assistant Version 3.6, and firmware version 3.08. My iPhone app is version 1.0.48.
    Any info appreciated.
  2. rbhamilton
    I did it. Didn't notice any problems or actually any differences either. Oh it reset my video counter sequence...
  3. Mopar Bob
    Connecticut, USA
    DrJoe: this is the camera firmware you are referring to correct? Not the WiFi? To update you have to load it to the SD card and start the camera. Do I have my facts right on this one?
  4. DrJoe
    Yes, I'm referring to the camera firmware, which updates via SD card slot on the gimbal.
  5. DrJoe
    Ok, so I went ahead and updated the FC300 firmware to 3.1:
    Results? Nothing much. It updated as expected once I changed the name of the file and loaded it onto the SD card and powered up the phantom.
    All I noticed was that the vision app on my iPhone now reports the Naza, and camera firmware version in the "about" tab.
  6. Meta4
    Meta4 Moderator
    Staff Member
    10 seconds on Google finds this
    The latest Phantom 2 Vision+ FC200 firmware (v1.3.0) fixes the issue of the camera failing to start in some cases and adds the ability to modify the filename prefix of photos if using the DJI SDK. Update your camera firmware according to your needs. Thank you for your support!
    Follow these instructions to update your firmware:
    1. Download the latest Phantom 2 Vision+ FC200 firmware from the official DJI website and unzip it.
    2. Copy the "firmware_plus_v1.3.0g.bin" file into the root folder of an empty Micro-SD card (less than or equal to 32GB) and rename the file to "firmware_plus.bin".
    3. Make sure the camera is turned off, and insert the Micro-SD card into the camera.
    4. Turn on the Phantom. The firmware update will begin automatically. A quick yellow flashing LED on the camera indicates that the camera is updating.
    5. When the quick yellow flashing disappears, the firmware has been updated. After a successful update, the "firmware_plus.bin" filename will change to "firmware_plus.bin.bak00". This file on the card can now be deleted.
    6. Restart the camera and the new firmware will be active. Check the firmware version in the DJI Vision app.
    Special Notes:
    a) During the update, do not turn off the camera, remove the intelligent flight battery, or take out the Micro-SD card. This may cause the update to fail and may require return-to-factory service.
    b) A quick red flashing LED on the camera after the quick yellow flashing indicates the update has failed. Please repeat Step 1 to Step 5 above without restarting the camera. Change to another Micro-SD card and try again if the update fails again.
    c) Ensure you are downloading the correct firmware. DO NOT mix up the camera firmware of the Phantom 2 Vision and Phantom 2 Vision+.
    d) The latest DJI Vision app (iOS App: v1.0.46; Android App: v1.0.56) is required.
  7. DrJoe
    I guess you have a better version of google than I do, LOL! I searched FC200 firmware upgrade 1.3. I got back a boatload of forum posts, but I never found a version info like you did. thanks for that.
  8. StevenQX
    Italy
    Small issue after camera fw update from 1.2.9g to 1.3.0g.
    After this update video taken from p2v+ are not anymore playable on my Samsung galaxy note 4 with std video player. I'm only able to reproduce them with mx player in software decoding mode, if I switch to the default hardware mode even MX player is not able to play recorded videos.
    Anyone here encountered the same problem?
  9. justin00
    Australia
    Always had that issue... I am using 1.2.9g I guess as I did not update yet.
    The fix is to lower quality of the video and it should work... Not really an acceptable fix to be honest though, would rather have better quality video.
    Maybe give it a try though, see if it works... if it does let DJI know so they can ignore you and perhaps one day fix it.
  10. StevenQX
    Italy
    The fix? Which fix you're talking about?
    Anyway I've checked video format with media tool and the strange thing is that video that I've recorded with 1.2.9g and video that I've recorded with 1.3.0g seems exactly the same...
Similar Threads - FC200 ver Forum Date
Does anyone have a older version then Phantom 2 Vision+ FC200 Firmware v1.3.0g for the camera Firmware Apr 19, 2015
FC200 Camera Version ? Phantom 2 Vision Discussion May 15, 2014
FC200 firmware ... same version number but different content Firmware Jan 27, 2014
FC200 Looking for HELP please Phantom 2 Vision Help Monday at 12:39 PM
Rotten Egg (DJI FC200) Phantom 2 Vision Mods Aug 10, 2017
