Professional Failed to start mission question
Discussion in 'Phantom 3 Help' started by trevsdad, Mar 14, 2016.
  1. trevsdad
    I'm just learning the Litchi app. I tried to execute a mission over the weekend and got a 'Failed to Start Mission' warning and of course, the mission wouldn't execute.
    The warning note (reason GS_Result_mission_Radius_over_limited) didn't make sense.
    Here's the Healthy Drones read out. What did I do wrong?
    ldallara924 likes this.
  2. With The Birds
    Australia
    You need to set a greater max flight distance (with aircraft connected so setting gets uploaded). The proposed mission would have exceeded the current setting.
  3. AJC
    AJC
    Make sure your 3D distance inbetween waypoints must not violate this distance criteria of not less than 0.5 meter or more than 2000 meters. This also applies to the 3D distance inbetween the first and last waypoint.
  4. With The Birds
    Australia
    I susoect the issue you describe here would return a "danping error" from the flight controller module in the SDK. This error encountered by the OP is within the Ground Station code and returned when the mission contains waypoints outside the max distance setting un the aircraft.
  5. trevsdad
    What do you mean by "...3D distance"?...is this different from max distance?
  6. trevsdad
    'Birds', you talk about "...a danping error"...what's that?
    Some clarification please?
  7. With The Birds
    Australia
    Damping error can be returned by the flight controller component of the DJI SDK when the mission is uploaded (relates to the curves described by the waypoints being outsude a particular range). I dont yjink that is your issue. I suspect you will find your planned mission would have taken you outside the maximum distance from home stored in the aircraft. Fire up DJI go with the aircraft connected and you can easily change that setting.
  8. trevsdad
    This was done (encountered) with the Litchi app not DJI GO, but it sounds like "two sides of the same coin" so to speak?
  9. With The Birds
    Australia
    I understand your issue was in litchi. It uses the DJI SDK's and that is where the errors are generated.
    I suggested you use the go app to check the maximum distance setting (it is stored in the phantom). You can probably check and change this setting in litchi also.
    You will find that your attempted litchi mission would have flown outside the maximum flight distance setting. Thats why it could not execute. Im not sure how else i can explain this.
  10. trevsdad
    ...copy that, understood. Thanks!
  11. With The Birds
    Australia
    No worries.... happy flying!
  12. AJC
    AJC
    3D distance is your x, y and z axis. X being longitude, Y being latitude and Z being altitude.
  13. Wolfiesden
    Milwaukee, WI, Ft Walton Beach, FL
    3D distance as in it includes horizontal distance and vertical distance. If way point 1 to 2 is only 10' apart horizontally but wp2 is 200' higher, then the 3D distance is 200 something feet (no I am not going to calc the tangent) while the horizontal distance is only 10' and the vertical distance is 200'.
  14. AJC
    AJC
    Correct. The 3D distance cannot be less that 0.5 meters and more than 2000 meters. This also includes the distance inbetween the last waypoint and the first. Otherwise you will get a "failed to upload mission"
  15. With The Birds
    Australia
    The OP didnt get a failed to upload error, the flight controller returned "mission_Radius_over_limited". The high level explanation being "The radius of the mission is over the acceptable limit". The mission planned would have exceeded the maximum flight distance recorded in the phantom (easily changed in DJI GO and probably the litchi interfaces).
    The issue you are accurately describing returns a different error on failing to execute.
  16. trevsdad
    This makes sense. Thanks for the other 3D explanations but 'Birds' is correct about the error message I described in my original post. I'll post the result after I make the corrections and fly through weekend.
  17. With The Birds
    Australia
    Im pleased you got it sorted... Happy flying!
  18. ldallara924
    Medford, NJ USA
    Thanks for all the help, I will try the suggestions and see if I can fly a Litchi mission.
Similar Threads - Failed start mission Forum Date
litchi error: failed to start the mission (reason: the mission is not initialised) Control (Go, Litchi, etc..) Nov 21, 2016
Litchi error message "Failed to load SDK -1010 Restart Litchi P3S Standard/4k Discussion Feb 9, 2016
Intelligent flight mode: Failed to start... Pro/Adv Discussion Sep 17, 2015
Professional P3P bricked and FW failed upgrade Phantom 3 Help Yesterday at 9:55 PM
P3 Firmware Firmware fail: [01886141][19 00] Firmware upgrade finish failed (step = 2, err = 0x08) Firmware Yesterday at 4:45 PM
