jedi88 said:When the Drone is in fail safe / return home and you want to take control when you see it, what do you do?
In China, formal documents (Traditional Chinese) the content starts top right and then moves down and to the left. It is quite common to see notices (on the metro etc) where the first item is on the right and the second is to the left of it. I think the controller switch numbering is a result of this.Pull_Up said:No problem, I think mist of us think it would make more sense to have had 1 on the left...
yes those crazy right to left ChinamenPull_Up said:No problem, I think mist of us think it would make more sense to have had 1 on the left...
jedi88 said:So.....
A few questions:
1. Do I need to set S1 att mode in software ?
2. Should I set a switch to auto fail safe ? OR should I turn the control off to get it home?
If your new to Vision, remain in out-of-box Vision mode until you you're comfortable flying it both nose-out & nose-in without encountering mobile trees, walls, water, and warm-blooded life forms and until you've perfected making reasonably good controlled landings.jedi88 said:So..... A few questions:
pault said:@iDrone, assuming you are not using Manual, which is your preference for Sw1 posn 3 (down) Failsafe or Failsafe Auto Land ? (can not remember exact options).
jedi88 said:pault said:@iDrone, assuming you are not using Manual, which is your preference for Sw1 posn 3 (down) Failsafe or Failsafe Auto Land ? (can not remember exact options).
Ok, I am not going to enter Naza mode for now
Last question....
If I want to initiate auto-home - I turn control off
If I want to recover and auto land - Throttle down, s1 middle and turn on control ? ( please someone give me this)
Pmcdn said:When flipping S1 down to Failsafe and then back to GPS, does it revert back to GPS lock pretty quickly or is their a lag?
