FAA said:a. You operated the aircraft directly towards an individual standing on a UVA
sidewalk causing the individual to take immediate evasive maneuvers so as to avoid
being struck by your aircraft.
b. You operated the aircraft through a. UVA tunnel containing moving vehicles.
c. You operated the aircraft under a crane.
d. You operated the aircraft below tree top level over a tree lined walkway,
e. You operated the aircraft within approximately 15 feet of a UVA statue.
f. You operated the aircraft within approximately 50 feet of rail way tracks.
g. You operated the aircraft within approximately 50 feet of numerous individuals.
h. You operated the aircraft within approximately 20 feet of a UVA active street
containing numerous pedestrians and cars.
L You operated the aircraft within approximately 25 feet of numerous UVA
buildings.
j. Y'ou operated the aircraft on. at least three occasions under an elevated pedestrian
walkway and above an active .street.
k. You operated the aircraft directly towards a two story UVA building below rooftop
level and made an. abrupt climb in order to avoid hitting the building,
l. You operated the aircraft within approximately 100 feet of an active heliport at
UVA,
Redline said:Can you sum it up?
ianwood said:This is huge. I think that pretty much frees us up from persecution by the FAA.
EMCSQUAR said:ianwood said:This is huge. I think that pretty much frees us up from persecution by the FAA.
Unless FAA takes action to change the laws (which is highly unlikely)
Byrdimaging said:The battle is won, but this was a HUGE loss in the war. All this does is make all of us look look bad, Take a look below at the list of things the FAA is complaining about and keep in mind, he was flying a fixed wing aircraft that does not stop unlike a multirotor. UVA is University of Virginia.
QuadZilla said:Byrdimaging said:The battle is won, but this was a HUGE loss in the war. All this does is make all of us look look bad, Take a look below at the list of things the FAA is complaining about and keep in mind, he was flying a fixed wing aircraft that does not stop unlike a multirotor.
This is a ridiculous post.
Byrdimaging said:QuadZilla said:Byrdimaging said:The battle is won, but this was a HUGE loss in the war. All this does is make all of us look look bad, Take a look below at the list of things the FAA is complaining about and keep in mind, he was flying a fixed wing aircraft that does not stop unlike a multirotor.
So you don't think the kind of behavior described in the FAA complaint is bad publicity for our community? I agree completely that this ruling is good for us. However, It's also an example of one rotten egg can make the whole carton smell bad.
OI Photography said:I think time has proven that the list of complains by the FAA you quoted won't signal the imminent disaster you fear, since it was originally filed months ago. Today's ruling basically stated that the FAA can complain all they want but can't do anything till they get off their butts and make an actual law.
They decided to base their case on the safety issue, which probably had a better chance of success than pursuing the commercial use angle, and even that wasn't good enough. The judge didn't say "he wasn't flying unsafely", he said "you can't do anything about it right now"
QuadZilla said:You need to educate yourself more before commenting lest you continue to post this kind of stuff. Google is your friend here.
Byrdimaging said:I realize it won't have an immediate effect. However, it's fuel for their debate, they can't just make laws without an approval process, currently any laws they make won't get approved because there's no need for laws. With cases like this to cite they will be able to show a need for those laws.
The FAA doesn't make laws. It makes regulations. And this ruling has no bearing on the FAA's scope of responsibilities. It just says the FAA does not currently have any enforceable regulations that support their claims in the case. This ruling does not in any way prevent the FAA from defining new regulations pertaining to the commercial use of multirotors and model aircraft. Once those regulations are defined, they can be challenged as to whether or not the FAA is overstepping its remit.Byrdimaging said:Read my response above and go google how the FAA actually makes laws. I can 100% guarantee that when the FAA does submit proposed laws this case will be cited.
The guy was paid to do it by UVA!Byrdimaging said:Bottom line is reckless behavior like this gives us all a bad name. That's all I am trying to point out.
ianwood said:The guy was paid to do it by UVA!
QuadZilla said:thongbong said:ianwood said:The guy was paid to do it by UVA!
they should have paid one of us Phantom Pilots to do it. :lol:
Please explain how you imagine that a Phantom could capture the same footage.
QuadZilla said:thongbong said:QuadZilla said:For someone who has been kicked out of this forum 3 times, you sure dont understand a joke.
For someone as confused and clueless as you have proven to be, it's difficult for normal folks to discern where the usual idiocy ends and a "joke" supposedly begins.
