External GPS antennae?
Discussion in 'Phantom 2 Vision Discussion' started by ProfessorStein, Jul 13, 2014.
  1. ProfessorStein
    Portland, OR
    So... I think I painted myself into a corner... literally.
    I gave my P2V a new paint job, and I'm noticing that I have slightly reduced GPS reception (my backyard now only shows 5 satellites or less, when I used to have 6 to 8).
    Whoops.
    So, rather than buy a whole new replacement shell, or try to remove the paint, I'm wondering if there's an external antennae I can mount on the shell. Figure it could give me better GPS just in general, which could always be a good thing.
  2. Pull_Up
    South Oxfordshire, UK
  3. ProfessorStein
    Portland, OR
    Have not, Pull_Up, but I'll certainly have a go at it now. Pretty easy mod... and if it works, awesome!
  4. svinkatnad
    Did you disassemble the whole thing? Maybe the something that I wasn't assemble properly and something making pressure in one of the cable or something like that. If you did that, you may want to watch this video on how properly dis/assemble yours.
    DJI Phantom Paintjob Part 1 - Disassemble - http://youtu.be/6Fyo2GAeU2w
    DJI Phantom Paintjob Part 3 - Reassemble - http://youtu.be/5hnerDEXIUk
  5. Byroman
    Libby, Montana
    Remember that GPS satellites are constantly in motion. You may have 6 today...11 tomorrow...5 ten minutes from now.
    Did you try again later to see if there were more sats available? Or, perhaps try a different flying location?
    I'm not ruling out the paint idea... just think that there would have to be a serious amount to impede GPS reception.
    Best of luck!
  6. gpauk
    Aberdeenshire, Scotland
    Yeah - use one of the many satellite apps to show you how many sats are actually above the horizon, then allow for obstructions, and see what you should get.......
  7. ProfessorStein
    Portland, OR
    I did try later and then elsewhere, yes.
    I think the problem might be that the paint may contain metallic components... I'm still trying to confirm with the manufacturer. The can says "may"... obviously a generic label for the entire paint line.
    But... back to the original question... is there really no external antenna that would be compatible with the Phantom?
  8. ProfessorStein
    Portland, OR
    I have "GPS Test" on my phone, and use it pretty regularly before I fly. But there really is no correlation between how many sats the app sees and how many the Phantom sees. The Phantom has always been consistently lower, even before I painted it. The app would see 12, 14, 16 sats (even when I held my phone on the ground where I was planning to take off), and the Phantom would barely get a lock on 6 or 7.
  9. SanCap
    South West Florida
  10. ProfessorStein
    Portland, OR
    My only fear would be the cable. Seems pretty vulnerable hanging out there, particularly if I mount it on top of the Phantom... between the props :/ I was hoping for something stalk-mounted... where the cable would feed down through the mount.
    But, at least it's a start. That should just plug right into the Phantom's NAZA bus, right?
  11. ProfessorStein
    Portland, OR
    But... yeah... for that kind of money, I'd be better off just buying a new (unpainted) shell.
  12. SanCap
    South West Florida
    Yes it will, I have recently converted my Phantom into a FW 450 using that puck although I do have the older version of the naza but the puck I linked is for the version 2 naza.
    [​IMG]
  13. ProfessorStein
    Portland, OR
    You what da what da what, now?? Just pulling the boards out of your Phantom and putting them in a 450 frame?
  14. SanCap
    South West Florida
    Yes, kind of. I originally pulled everything thing out of my Phantom 1 to build this waterproof quad http://www.phantompilots.com/viewtopic.php?f=4&t=4047&hilit=+waterproof. I could never get it to be as stable as I wanted it to be, there were heating issues and compass issues I believe. After I gave up on the waterproof idea I wanted to build something that had easy access to all components and was easy to work on and add stuff to. I replaced the GPS/Compass with the puck style, new style Naza LED and added a new receiver so I could fly this new 450 as well as my 550 with the same Hitec Aurora 9 transmitter. I desoldered the esc's reinstalled to the new lower board of the 450 using the same motors from the Phantom. The 450 frame was like 40 dollars. One of my goals was to have both my copters using interchangeable parts. I am flying it with a 3s 5100 mah battery and get almost 15 minutes on it. I do not mean to hijack your thread but you asked and some of it applies :)
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  15. Pull_Up
    Judging by the twist on that puck you've got a lot of declination to correct for where you are! :)
  16. SanCap
    South West Florida
    I store it with the puck off and it was not ready for flight :)
Similar Threads - External GPS antennae Forum Date
Which External GPS tracker uses the people? General Discussion Mar 14, 2017
how many use a external GPS tracker Phantom 4 Discussion Sep 5, 2016
What external GPS are you using with your iPad? Pro/Adv Discussion Apr 2, 2016
Follow me/External GPS Question Pro/Adv Discussion Sep 8, 2015
External GPS receiver for follow me Pro/Adv Discussion Sep 7, 2015
