Exiting Assistant software
Discussion in 'Phantom FC40 Discussion' started by sherpa, Sep 29, 2014.
  1. sherpa
    White Lake, Mi
    Assembled my fc40 today and did the software but I'm not comfortable with the way you exit the program. what am I missing. How do you confirm everything took?
  2. jerrymac12000
    Colorado Springs, CO
    Exit out of the program by hitting the "x" in the upper right hand part of the screen. Then unplug. It works every time for me.
  3. OI Photography
    Clarksville, TN
    Any values you change in the Assistant will be in red until you hit return and they are written to the NAZA, then they turn black.
    If you ever want to confirm a setting change happened properly, just power cycle your Phantom then reconnect to the software and check them again :)
  4. sherpa
    White Lake, Mi
    Great thanks for the replies!
  5. Rustysocket
    It took using the program many times to become comfortable that my changes were being written to the device. Some values when changed such as distance limitations will prompt you to press enter to write the values. I have done it so many times that I now trust it. but the first few times I would hook the phantom back up to check that the changes were being read correctly. Especially when setting up the failsafes.
    It would be nice if the software had a "read current config from device" feature or something along those lines and something a little more elegant than the red X to close. but it is what it is and it does work.
Similar Threads - Exiting Assistant software Forum Date
Exiting Tap To Fly and Go 4 App Blanking. Phantom 4 Pro Help May 27, 2017
Exiting Apps on the pro plus controller Phantom 4 Pro Discussion Jan 14, 2017
DJI Assistant does not see P3 4K Standard/4k Discussion Aug 13, 2017
DJI Assistant 2 Phantom 4 Discussion Aug 4, 2017
dji assistant 2 "transmitting" Phantom 4 Discussion Jul 29, 2017
