Exit from fail safe mode in Naza
Discussion in 'Phantom 2 Vision + Discussion' started by WebMaximus, Aug 15, 2014.
  1. WebMaximus
    I'm sure I read the answer somewhere already but what is the procedure to exit from fail safe mode in Naza if the Phantom has entered fail safe mode due to a lost connection?
  2. ToThePoint
    Antwerp, Belgium
    S1 in middle position ( ATTI mode )
  3. WebMaximus
    Thanks!
    And then I can go back to GPS mode by flipping S1 to the upper position as I normally would?
  4. DBS
    DBS
    Ft. Pierce, Florida
    Yes... you can do that immediately if you like... quick down/up on the switch and you take over in GPS right away... IF your back in range
  5. WebMaximus
    Perfect, thanks again!
    I hope I won't need this info IRL but I like to keep myself well prepared for any unplanned events...
Similar Threads - Exit fail safe Forum Date
Exiting Tap To Fly and Go 4 App Blanking. Phantom 4 Pro Help May 27, 2017
Intelligent Mode: Could not exit Tap Fly Phantom 4 Pro Help Apr 4, 2017
descending. exited visual avoidance system General Discussion Jan 20, 2017
"Attitude too Large. Exit Backward Obstacle Sensing". Phantom 4 Pro Discussion Jan 19, 2017
Exiting Apps on the pro plus controller Phantom 4 Pro Discussion Jan 14, 2017
