Prowler said:I have a bad ESC and have all v2.0 can I replace just one ESC with a V2.1 and it will work with all the other three V2.0 ESCs?
mad in nc said:OK... look about it this way and think about this analogy.
You have an electric car you drive every day with 4 motors and control ESCS's (one pair per wheel). In traffic that you want to go from A to B. On the road passing hundreds of homes or locations. Do you think the car service manager would change the ESC of your electric car to a not known but "rev'd" (aka the difference between 2.0 and why they built 2.1) controller with assuming the risk of his perosnal choice? What if any is the point of the revision. Has somebody or an engineer signed off on the mix and match. Will the service mgr of the auto sign off as a company rep that it's ok?
justin00 said:I would just pay the $100 and buy 4 new ones.
If anyone comes in and says "yes it will work" do you really want to risk your $1000+ device ?
Unless DJI tell you it will be fine and guarantee to stick by there response/advice, in case it is not fine (which I really doubt they will do) then I would just pay the $100.
Also if 1 has gone bad, how do you know the others won't go bad either ? Or did you have a tip over or something like that ?
ksphantom said:I tried mixed two ver 2s and two ver 2.1s.
First test flight after install It took off, wanted to climb uncontrollably even at mid throttle. It seemed like it was pulsing as it went up like the naza was sending a signal to the escs that wasn't being interpreted equally. I had to pull the throttle stick down almost all the way to bring it back down and had a minor tipover on landing.
Changed the remaining two escs to ver 2.1 and it flew fine again.
It may have been a fluke or something else, but it never flew weird like that again after switching to all 4 escs the same.
