ESC error. One bad motor???
Was given a bunch of crashed p3 professionals. Didn’t run this one b4 hand but shell was cracked pretty good and 1 motor was packed with mud from crash. I replace shell and go to start. It will fire all 4 motors then turn off. Or will fire 3 motors then shut off. The esc error code will come on. Done multiple restarts and calibrations. When I do get it to finally take off the 1 motor will stall or cut out. Other there work perfect. Could this just be a faulty motor that needs replacing. Thanks for reply’s. Have 3 phantoms and first time on this site!
Reactions: MotorCycle-Man
Flynelly......WELCOME to the Phantom pilots forum !........ and i hope that you get this problem solved asap......good Luck
Don't be oiling the motor or glueing anything till you get >> HELP here !
If you have a bad motor you will get a esc error just replace that motor. looks like you might be doing a bit of tinkering with 3 crashed P3P...Welcome
shimuafeni fredrik
