edunwody said:
What kind of range are you getting on your downlink.
I had one installed today. 5.8ghz. With cloverleaf antennas.
Goes out about 75 to 100 ' and I loose signal.
Any thoughts?
What TX and RX are you using? I have the DJI AVL 58 500mw with DJI antenna's and have got pretty good range with picture only just starting to break up around 600m LOS and even behind trees I can get 200m or so range out of it. Supposedly can do 1.5km but maybe my RX antenna isnt in the greatest position but I really havent pushed the range all that much out of it yet.
The immersion 600mw should do even better and make sure you have some good antennas as cheaping out on these is going to kill your range pretty quickly even with a decent tx. In specs the DJI OSD supports remote feed switching and this should work well with the DJI FPV setup but also any other decent setups.
