Dual (Parallel) Batteries on Boscam RX-LCD5802 ?
Discussion in 'FPV (First Person View)' started by Xrover, May 20, 2014.
  1. Xrover
    Los Angeles, Ca
    I have a Boscam RX-LCD5802 Diversity 5.8ghz Monitor with built in 7.4V 2400 mAH Lipo Battery.
    A friend has the same monitor but busted his LCD screen so he gave me the whole thing.
    Can I pull his battery and run it in Parallel with mine to get double the mAH? And can I charge the setup using the stock 2000mAH 12V charger.
    Should work right?
  2. Xrover
    Los Angeles, Ca
  3. macheung
    You can, but why?
    The stock monitor battery already way out last your flight battery, probably by a factor of 5. The extra complexity and weight would probably not be worth it
  4. Xrover
    Los Angeles, Ca
    Lol. Actually it does last through 5 Flights
    So I guess i'll just keep the other monitor for parts.
    I am learning that the Lipos are not as simple as just Paralleling AGM or Lead Acid batteries.
    Thanks for the reply.
Similar Threads - Dual (Parallel) Batteries Forum Date
Dual controllers for the P4P? Phantom 4 Pro Discussion Jul 17, 2017
MaxxUAV.com Finally getting Dual Band Antennas! Phantom 4 Pro Discussion Jun 21, 2017
Inspire 1 -Mint- Dual Remotes, 5 Batteries Classifieds Jun 9, 2017
p3s...dual ios devices ? Standard/4k Discussion Apr 26, 2017
Can you use a cable splitter to run dual iPads? General Discussion Mar 19, 2017
