Drone won't stop beeping
Just got a P3 (So Excited!) went to update firmware and all hell broke loose! Now it won't stop beeping and I can't upload anything. Looked on you tube and other sites and and everything said to download the update on SD card and then put in drone, it would fix itself. Well that's all fine and dandy but where the heck do you find it? One site said to download it off your phone under the DJI app. The only problem is that iOS won't let you open any app files when hooked up to your computer only DCMI. PLEASE HELP!!! Can someone please rescue me?
Sean
Check to see if the left control stick is stuck in the down position. The controller will constantly beep until you release it.
1 push the left stick up, then CONNECT your phantom 3 via wifi connection (or cable if you have advance or professional). Go to dji go and enter camera view. It SHOULD stop beeping unless you are going to update it. You might have to do an IMU calibration and a compass calibration if it doesn't stop beeping.
cokersean20
