Standard Drifting in gps mode under 25 feet.
Discussion in 'Phantom 3 Help' started by ksumers, Sep 18, 2016.
  1. ksumers
    New to the forum. My standard is drifting in gps mode under 25 feet. Seems to be much better above 25 feet. Didn't drift at all when it was new. Have around 30 hours on it now. No crashes or any damage. Tried recalibrating IMU, compass, and gimbal. Made no changes. Sorry, if this question has been addressed before. Any help is appreciated, thanks.
  2. WilliamM
    Lancaster, Pa.
    Drifting how much?
  3. ksumers
    It slowly goes down to the ground and moves side to side a few feet.
  4. WilliamM
    Lancaster, Pa.
    That's not normal if you have it in P-mode, it should be only a few inches side to side. Up and down could be a bit more as that's not a GPS function.
    sinxa likes this.
  5. ksumers
    Do you have an idea of what might be causing the problem?
  6. RodPad
    Pacific,NorthWet, 97031
    Humm,
    Welcome to the forum!
    The only thing I got is playback your flight and see if what the controls are showing when you are hovering.
    If the Phantom drops down, does it come back up? Or does continue dropping or ?
    Rod
  7. WilliamM
    Lancaster, Pa.
    You said you calibrated IMU and compass, that would be my suggestion. How many GPS satellites do you have locked.
    sinxa likes this.
  8. ksumers
    It will slowly go down until I'm forced to send it back up.
  9. ksumers
    10-13 satellites.
    sinxa likes this.
  10. sandman259
    sandman259 Guest
    I notice if I turn my vps off on my PSA under 25ft it wonders a little compared to having it on is a lot more stable.
  11. RodPad
    Watch your controls on a playback, or maybe something do with the barometer.
    All I got so far. :rolleyes:
    Rod
  12. WilliamM
    Lancaster, Pa.
    That's plenty enough. Maybe try to calibrate the remote?
    sinxa and auen1 like this.
  13. kirk2579
    Girard. ohio
    the IMU would be responsible for holding it at hover with alt and gps inputs.
    I would re do the IMU calibration and make sure it is abslotulety level motor post top to post top (same plane as props).
    the other quick and easy thing is use your spare props if you have a set to verify balance of the props.
    if they are off even a little bit , or nicked etc.
    the quad will and can wonder around a bit
    good luck and have fun flying
    sinxa likes this.
  14. sinxa
    IMU cal. . . Noted
    Compass cal. . . Noted
    GPS sats. . . Noted
    Stick cal. . . Noted
    Props replace. . . Noted
    What else could be wrong?
    Have you tried on another area which is clear and open?
    Sent from my SCL23 using PhantomPilots mobile app
Similar Threads - Drifting gps mode Forum Date
Phantom 2 drifting more than ever on GPS mode General Discussion Nov 9, 2014
GPS Mode Drifting Phantom 2 Vision + Discussion Oct 28, 2014
drifting a lot in gps mode Phantom 1 Help Oct 10, 2013
$1800 loss in 5 seconds!Losing GPS and drifting 50mph crash Phantom 4 Pro Help Jul 3, 2017
Gimble sideways on turn on and got GPS indoors and started drifting Phantom 4 Pro Discussion Apr 6, 2017
