Is it possible to downgrade from the latest firmware back to, I believe, 3.2/3.06. Ive seen conflicting reports as to whether it is possible. I upgraded everything except for the batteries, which didn't give me an option to update for some reason.
That sucks... Even with some multistep workaround...msinger said:There is no way to downgrade the firmware.
max said:That sucks... Even with some multistep workaround...msinger said:There is no way to downgrade the firmware.
N017RW said:max said:That sucks... Even with some multistep workaround...msinger said:There is no way to downgrade the firmware.
Did you visit the page I linked?
Today was the first I've heard in months that you can't downgrade.
Got any tips for things to avoid?LiLPhantom said:be careful working down in firm ware if you haven't been there before...
msinger said:Got any tips for things to avoid?LiLPhantom said:be careful working down in firm ware if you haven't been there before...
Trees? Hmm... I don't think they come into play when installing software...happydays said:msinger said:Got any tips for things to avoid?LiLPhantom said:be careful working down in firm ware if you haven't been there before...
Trees :mrgreen: :mrgreen: :mrgreen:
msinger said:msinger said:Got any tips for things to avoid?LiLPhantom said:be careful working down in firm ware if you haven't been there before...
LiLPhantom said:Fplvert said:
Pick the assistant version you want from droneslinger's site. Install that version on your desktop. When you connect the bird select the version and choose update.
Nothing to be worried about, really msinger. You are a pilot, the restrictions on speed and descent (+NFZ) are the main things.
Exactly. Just stay away from 3.0!
2.0 you will have no flight restrictions, your bird can descend really fast, be careful on that one if your not used to it, otherwise you should be good to go...
jasonb777 said:Why can't someone on this forum with a wealth of computer programming knowledge design a program that will allow the phantom to operate like the 1.08 with all the benefits of the 3.08?
