Don't laugh at my idea.
Discussion in 'General Discussion' started by C0ps, Aug 28, 2015.
  1. C0ps
    I'm thinking of using my phantom to put Christmas lights on a very tall tree of mine. Any thoughts on how to disconnect the line once I reach the top?
  2. Meta4
    Meta4 Moderator
    Staff Member
    Think of the weight of the string of lights.
    You might be better to use the Phantom to string a light (weight) line and use that to pull the lights into place.
  3. bbfpv
    Long Island, NY
    bigger problem is how are you going to attach the lights to power? either the lights to go from top to bottom will be too heavy, or the extension cord going to the lights will be too heavy.
  4. shane0926
    Only simple way that comes to my mind is a hook of some sort on a rigid wire or "pole" that extends down a couple feet. So once the light string is resting on the tree, you descend slightly then ascend and it should let go. Of course this has the potential to failure miserably, and this is assuming no complex electrically controlled device is being used.
    Though if you wanted to go a different route and had a spare receiver and transmitter lying around...it would not be difficult to throw together a device with a servo that straps to the landing gear.
  5. C0ps
    Hmmm, not a bad idea.
  6. C0ps
    I would connect everything on the ground.
  7. JBG
    JBG
    JDGecko likes this.
  8. III% Streve
    What in the world is a boon lift? Can I get one at the frigerator store? I might do that for my wife on valentimes day!!
    bbfpv and Chris Grazioso like this.
  9. Skip holden
    Tee shirt cannon
  10. III% Streve
    You can get one that shoots punkins! I be like... ****!
    BlackOpsTeamster and dirkclod like this.
  11. Pete Leare
    Lakeville MA
    I would rather use a slingshot with a 1oz fishing weight to fire some 50lb test over the tree and pull the lights up that way.. Sure not as exciting but keeps the P3 safe on the ground..
  12. RoyVa
    Virginia
    Wait for a Wendy day and fly a kite, you'd be better off. It has a string already.
  13. dirkclod
    dirkclod Moderator
    Staff Member
    Amory Mississippi
    I use my little pet monkey to get ours up there and only have to pay a few bananas to reward him :)
    JK;) I would go with Pete and the slingshot on this one as I have seen it done :)
    750r likes this.
  14. JBG
    JBG
    I guess the link to "boon lifts" wasn't educational enough for you :)
  15. III% Streve
    I was going to post a pic of a boon lift.. but figure partial nudity would get me banned!
    #15 III% Streve, Aug 28, 2015
    750r, BlackOpsTeamster and JBG like this.
  16. sclabrl
    Send me the video of that!
    robsquad and BlackOpsTeamster like this.
  17. taroh
    Yokohama, Japan/Taichung, Taiwan
    First, tie thin fishing line (that has enough tolerance for friction) to the landing gear of your bird, and fly over the tree, pull away horizontally, then return back nearer to tree, descend, so that the line pass over ”Y" shaped branch near the top of the tree. Then, tie thicker wire to the line, pull from opposite. Tie more thick wire to the 2nd wire and pull. Finally fix a light (maybe with support bar) and electric line to the 3rd wire, and pull. The 3rd wire could be left.
    If the tree don't have "Y" shaped branch at the top, prepare "Y" shaped statue (or pulley), of which below part is reversed funnel, hung it with hook with "V" shaped line tied to both two P3 landing gears. Fly above the tree, aim with FPV camera full down, slowly down, and when the top of the tree is inserted into funnel, descend a bit to detach the hook from "V" shaped line, ascend P3P. Then do the above operation.
    The problem is to fix the light (with bar) on the top of the tree - how about using "POI" operation? The 3rd wire above is tied parallel with thin line (with big friction this time), you tie the line to P3 landing gear softly, fly up, do "POI" action turning 20-30 rounds around the light and bar, then fly away from the tree so remove the line from gear.
    Actually I don't believe this plan goes well, sorry. :)
    #17 taroh, Aug 28, 2015
  18. BlackOpsTeamster
    St. Louis metro east
    Yes Dirk, and a quad just happened to see the poor little guy up on the eave of your house and got a picture!
    [​IMG]
    I heard it mentioned they were gonna report you to the ASPCA...
    Just a heads up...
    HA!
    BOT
    #18 BlackOpsTeamster, Aug 28, 2015
    750r and dirkclod like this.
  19. StumbleBee
    Nashua, NH USA
    LOL, I just read all the vicious and cruel remarks above. That's what I like about this forum. :D
    FWIW, my solution to the tree stringing question would be to change religions. Easier, safer and cheaper at Christmas.
  20. StumbleBee
    Nashua, NH USA
    I say we Velcro that guy to an Inspire 1 and drop him on the top of the tree with a rope to pull up the lights himself. I'd pay good money to see that.
Similar Threads - Don't laugh idea Forum Date
Super Newbie Question, Don't Laugh General Discussion Jan 18, 2016
Please don't laugh. Well I guess you can but I'm kinda bummed Phantom 3 Help Jun 30, 2015
Don't Laugh It Nearly Works Photos and Video Mar 15, 2014
Don't fly in Thailand! General Discussion Jan 10, 2018
Litchie , can you create a mission on s7 don't own desktop Phantom 4 Pro Help Jan 7, 2018
