does the ipad mini work with dji go?
Discussion in 'Pro/Adv Discussion' started by cypher007, May 11, 2016.
  1. cypher007
    my son has an original ipad mini. I might borrow it to fly as my LG G3 screen is a bit small. I did find some conflicting reports as to if it runs ok or not.
    so far I haven't tried it, but it has let me install dji go.
  2. ThommyBoy
    Midwest
    When I used to use the Mini it would overheat in the summer, start to pixelate and then the screen would go black. It can't handle the combination of the heat and the power draw of the Go app. I now use an iPad Air 2 with zero problems.
    cypher007 likes this.
  3. msinger
    Approved Vendor
    Harrisburg, PA (US)
    The iPad Mini 1 is too slow. You'll need at least an iPad Mini 2.
    meissner58 and cypher007 like this.
  4. cypher007
    anyone know if a rock chip 3188 will run it?
  5. DennyBoBenny
    I use an iPad Mini 2 and it works well, but the screen isn't as bright as my iPhone 6+ so it's hard to see in bright sunlight. I don't know if newer mini models have a brighter screen.
  6. Procharged97
    Canterbury, CT
    I used the ipad mini 1 for a month and the screen would flicker every time and the video playback would be missing footage...I now have the mini2 and have no problems with it at all. I use a sunshade/hood when its really sunny out
  7. cypher007
  8. msinger
    Approved Vendor
    Harrisburg, PA (US)
    The tablet holder can only extend to 6.75 inches. You could use the Lenovo Yoga 2, but you'd need some type of extender to hold it since it's 7.63 inches wide.
  9. Pappy44
    you can use the mini original to do everything except fly...once flying, it can't handle the information fast enough, and you will lag badly. I also suggest the mini 2.
    meissner58 likes this.
  10. DPD
    DPD
    I would recommend mini 3. And works flawlessly with the DJI go app. I went with the cellular&wifi, could have just gone with the wifi only but I like the convenience of getting my maps on site, and Cellular for follow me mode.
  11. Matt W Ruff
    Nashville, TN USA
    I had a mini 2 that worked ok but the new mini 4 works like a champ. The full size iPad is too big and the iPhone 6 Plus is ok but to me the mini is the perfect size!
    sonof40 and meissner58 like this.
Similar Threads - does ipad mini Forum Date
Does the P4 come with a holder big enough for iPad minis? Phantom 4 Discussion May 17, 2016
Does Autopilot work with iPad mini 2 Pro/Adv Discussion Feb 21, 2016
New app in landscape mode, doesn't fit on iPad mini. Standard/4k Discussion Dec 21, 2015
Professional Micro usb cable does not fit in my Ipad mini 2 Phantom 3 Help Jun 23, 2015
Advanced How does the iPad mini 2 work with the Pilot App? Phantom 3 Help May 29, 2015
