  1. PhantomJAK
  2. zivalfred
    I just ordered mine yesterday and reading all threads here made me anxious. How far does your p4 go?
  3. PhantomJAK
    Check out the video ;)
  4. oblivie
    [​IMG]
    Not sure about yours but my p4 goes very very far
  5. PhantomJAK
    That's about what I would expect on an open coast. Also, that's round trip. Thanks for sharing!
  6. Blue Bird
    Dade County, Florida
    Great vid regarding range on the P4! That isolation away from interference in open fields definitely will always improve range.
    The best test so far! What are you getting with the antenna mod?
  7. oblivie
    Yeh ... Around my neighborhood ,that's is wifi congested, I get 1 and half miles average
  8. PhantomJAK
    Have not tested with the mod on the P4, but my P3 got 15,400 ft. with the DBSMods kit. Check out the video here
  9. Blue Bird
    Very Cool! Let us know when you do a mod with the P4. I am curious what the range will be then.
  10. volace
    [​IMG]
    This is my maximum range with a cheap wind surfer antenna.
    My only complaint is being very sensitive to direction. I wish I have someway to make it less sensitive to direction as you know sometimes along the course you are not sure if you direct your antenna the exact right direction of your bird , needless to say that I can't get this range if I direct my phantom to more residential areas
    Or over big building.
    Blue Bird likes this.
  11. PhantomJAK
    Thanks for sharing! Love the Sunnyvale area!
  12. phantom13flyer
    Sent from my iPhone using PhantomPilots mobile app[/QUOTE]
    Have you
    Sent from my i
  13. mnewxcv
    is that open field or with trees/houses?
  14. phantom13flyer
    Volace have you looked the options available at maxxuav.com . I got there boosted setup and my range now far exceeds the battery power of my p4.
  15. PhantomJAK
    Good tip.
  16. zivalfred
    Hello! could anyone please tell me how upgrade extra battery for p4. Im a beginner. Thanks
  17. Phantomfreak
    Got my P4 out 20,145 ft. with windsurfers only, one way.. ImageUploadedByPhantomPilots1462729171.926321.jpg
    Here's my best with my P3P.. same flight path, same windsurfers..
    [​IMG]
    I've done back to back tests on different flight paths, it's always been the same.. The P3 consistently gets around 2,000 to 2,500 ft. greater distance over longer flights, I guess that's appropriate given the P4 transmitter puts out around 20% less power. At first I was a little bummed because of this, but If I really wanted to address the issue I would just install a Itelite antenna or something. But the ranges I'm getting of around 4 miles distance work for me.. So I'm happy.
    #17 Phantomfreak, May 8, 2016
  18. snowghost
    SoCal, USA
    How much less is the range without the Windsurfer?
Similar Threads - Does Phantom better Forum Date
Phantom 4 does not connect to the Windows PC DJI assistant 2 Phantom 4 Help Dec 16, 2017
What does s2 do on my dji phantom 3 standard do Standard Dec 1, 2017
Phantom 4 does not support ipad2 mini. Phantom 4 Help Nov 25, 2017
DJI Assistant software - does it work with the Phantom 3 Pro Pro/Adv Discussion Oct 2, 2017
Phantom 3 advanced crashed in water and camera does not work Pro/Adv Discussion Sep 4, 2017
