Does anyone know how to decipher the hidden .txt file?
here is the last attempt I made to update firmware:
[00024795]========== remo-con disconnect. boot(15) ============
[00024901]Packet [C:\P3S_FW_V01.08.0080.bin] detected, card sn [0xda5e1c73].
[00025004]Packet upgrade start...
[00025113]Packet checking...
[00025226]Packet vlink 01.08.0080 <-> 01.07.0060.
[00025328]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 1).
[00025434]Done.
[00025542]Version checking[1]...
[00038277][03 05][00] device not detected.
[00050890][03 06][00] device not detected.
[00051014][04 00][00] v1.48.0.0 -> v1.44.0.0
[00063632][11 00][00] device not detected.
[00076248][12 00][00] device not detected.
[00088856][12 01][00] device not detected.
[00101468][12 02][00] device not detected.
[00114081][12 03][00] device not detected.
[00136691][15 00][00] device not detected.
[00149295][17 00][00] device not detected.
[00161905][17 01][00] device not detected.
[00174515][19 00][00] device not detected.
[00174625][01 00][00] v1.25.5432 -> v1.23.4920 need upgrade
[00174735][01 01][00] v1.25.5432 -> v1.23.4920 need upgrade
[00187335][09 00][00] device not detected.
[00187444]Done.
[00189557]Waiting for user confirm...
[00199659]Timeout, start upgrade automatically.
[00199879]Firmware upgrading[1]...
[00200111][01 01] Firmware upgrade start...
[00230497][01 01] Firmware upgrade finished successfully.
[00230609]Done.
[00230711]Version checking[2]...
[00243330][03 05][00] device not detected.
[00255956][03 06][00] device not detected.
[00256066][04 00][00] v1.48.0.0 -> v1.44.0.0
[00268673][11 00][00] device not detected.
[00281286][12 00][00] device not detected.
[00293894][12 01][00] device not detected.
[00306507][12 02][00] device not detected.
[00319119][12 03][00] device not detected.
[00341742][15 00][00] device not detected.
[00354359][17 00][00] device not detected.
[00366967][17 01][00] device not detected.
[00379579][19 00][00] device not detected.
[00379687][01 00][00] v1.25.5432 -> v1.23.4920 need upgrade
[00379796][01 01][05] v1.23.4920 -> v1.23.4920
[00392404][09 00][00] device not detected.
[00392508]Packet upgrade failed at version checking.
any idea what that all means, or possibly my error?
From what I've read it looks like the FW can't find certain modules in the quad, someone with more knowledge will be along soon
"Packet upgrade failed at version checking. hmm."
What does that mean?
when you say go back to 1.10 then downgrade to 1.9, I assume you mean firmware version P3S_FW_V01.10.0090.bin and then downgrade to P3S_FW_V01.09.0060.bin?
If it's about P3 Std, then you've posted in a wrong forum.
Since people here mostly have Pro/Adv, they may not know that P3 Std sometimes shows a lot of "device not detected" messages for no apparent reason. But if it starts updating, on a second check, every version is filled correctly.
Still, I agree with the method proposed by ferraript.
Reactions: glosol
[00024621]========== remo-con disconnect. boot(15) ============
[00024732]Packet [C:\P3S_FW_V01.10.0090.bin] detected, card sn [0xda5e1c73].
[00024836]Packet upgrade start...
[00024955]Packet checking...
[00025064]Packet vlink 01.10.0090 <-> 01.10.0090.
[00025171]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00025284]Done.
[00025396]Version checking[1]...
[00037996][03 05][00] device not detected.
[00050607][03 06][00] device not detected.
[00050721][04 00][00] v1.48.0.0 -> v1.48.0.0
[00063331][11 00][00] device not detected.
[00075939][11 01][00] device not detected.
[00088545][12 00][00] device not detected.
[00101157][12 01][00] device not detected.
[00113770][12 02][00] device not detected.
[00126382][12 03][00] device not detected.
[00149009][15 00][00] device not detected.
[00161617][17 00][00] device not detected.
[00174232][17 01][00] device not detected.
[00186842][19 00][00] device not detected.
[00186954][01 00][00] v1.25.5432 -> v1.25.5432
[00187061][01 01][00] v1.23.4920 -> v1.25.5432 need upgrade
[00199666][09 00][00] device not detected.
[00199777]Done.
[00201881]Waiting for user confirm...
[00212001]Timeout, start upgrade automatically.
[00212223]Firmware upgrading[1]...
[00212459][01 01] Firmware upgrade start...
[00242836][01 01] Firmware upgrade finished successfully.
[00242948]Done.
[00243053]Version checking[2]...
[00255678][03 05][00] device not detected.
[00268295][03 06][00] device not detected.
[00268412][04 00][00] v1.48.0.0 -> v1.48.0.0
[00281037][11 00][00] device not detected.
[00293654][11 01][00] device not detected.
[00306261][12 00][00] device not detected.
[00319041][12 01][00] device not detected.
[00331654][12 02][00] device not detected.
[00344267][12 03][00] device not detected.
[00366894][15 00][00] device not detected.
[00379501][17 00][00] device not detected.
[00392115][17 01][00] device not detected.
[00404727][19 00][00] device not detected.
[00404841][01 00][00] v1.25.5432 -> v1.25.5432
[00404950][01 01][05] v1.25.5432 -> v1.25.5432
[00417555][09 00][00] device not detected.
[00417666]Packet upgrade failed at version checking.
Ahh, I see.. sorry, I got confused - P3S_FW_* if of course for P3 Advanced...
Well in that case your camera seem to be having issues talking to most of the other modules, probably because those modules are still at 1.10.
Reactions: glosol
Yes, the P3S_ part of the update file name is actually correct for the P3A.
1.10 is complete, but failed. do I go directly to the 1.9 firmware now?
Here is the weirdest thing ever. The .txt file had the full history of all the firmware attempts. until yesterday, and now it says history erased...
I didnt do the force firmware, just put the bin file on the sd and booted it up. So if I do force firmware, should I restart the 1.10 then 1.9?
I have one txt file from a week ago. Its long, whats the best way to post that?
if it doesn't contain "device not detected" at the end, it won't help - then at least tell me, what was the lowest FW you were at or you tried to downgrade to (since "device not detected" problem started)
if it does, attach it using that "Upload a File" button (it's just next to "Post Reply" button)
Reactions: glosol
I have only had it for a week, been trying to sort out why it doesnt fly. all I know is whats on the .txt file...
and thank you for helping me on this.
  • P3S_FW_LOG_AB.txt
Here is the very latest .txt file
  • P3S_FW_LOG_AB.txt
in the end, it doesn't matter if it was you or another pilot, so ok, lets assume it was someone else
at the beginning, Phantom was at 1.4.10
it was then upgraded straight to 1.9.60, that maybe wasn't the smart move
in the logs, there was "[11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support."
user panicked and tried to do many re-updates of 1.9.60, without success
his last action is unknown - maybe he forced stop the update or something, but it went wrong and boom, a lot of "device not detected"
then you come (I can see it according to the SD card serial number)
you also tried to reflash 1.9.60, no success
you flashed 1.10.90, but, of course, only 3 recognizable modules were updated
and then, you also tried to flash various firmwares, but no success in the end
there is big chance that AC is bricked and my advices won't work
so if you have warranty on it, you should report the problem to DJI
otherwise, the only chance I can see, is, that you need to keep downgrading the AC (maybe down to 1.4.10) and hope that in some firmware all modules will be recognized
downgrade only one FW by one, always using that debug file and after every downgrade check the status of recognized modules
(Maybe the best way would be - you do one downgrade, send me log and I tell you what to do next. But it'll take some time, I don't know if you are so patient.)
Reactions: glosol
wkflysaphan4
