Does anyone else get the shakes?
Discussion in 'General Discussion' started by OverheadAerial, Sep 2, 2014.
  1. OverheadAerial
    Augusta, GA
    I have discovered that after about 25 minutes of continuous flight time I start to get the shakes. I am 36 years old and I get the shakes!!! Does anyone else experience this and if so what causes it? Or am I just crazy?
  2. ProfessorStein
    Portland, OR
    Do you think it's nerves? Or carpal tunnel?
  3. OverheadAerial
    Augusta, GA
    It's not when I first start. It's after I've been flying for about 25 minutes so I don't think it's nerves. I don't know what carpal tunnel is...
  4. Buckaye
    Orlando
    I have familial tremors so I always shake :)
    Ted4797 likes this.
  5. CallMeAlan
    Newbury, UK
    After 25 minutes of flight time you're probably nervous that the battery is about to expire, and it's the nerves that are giving you the shakes!!
  6. OverheadAerial
    Augusta, GA
    At 25 minutes I am using my second battery about to switch to my third. I also can see my voltage on my Black Pearl. No stress over batteries.
  7. moe3754
    Colorado Springs, Colorado
    I get the shakes and a back ache but that is because I have had back surgery and standing that long puts stress on my lower back. If I fly for ten minutes it is long enough for me.
  8. ProfessorStein
    Portland, OR
    Sounds like you just need to pack a granola bar for a snack when you go out flying.
  9. Trackman1
    Ontario, Canada
    A bit hard to poke at the app screen is it? Some where between cold climate and nerves. Been there.
    I was real nervous when I first flew the P3. My sole experience with RC flight was with my squirrel of a helicopter. It's always headed for a tree.
    One or two flights a day and some recharge time in between and you get a lot more confident.
    Just take your time.
  10. PeakXV
    Canada
    Sometimes, but that's only when it's well below zero and I'm underdressed for the occasion.
  11. AdamO
    I to got the shakes the first time I saw my P3 hover off the ground. Maybe you could get one of those leashes you hook to the remote to let your hands rest when you get the shakes.
  12. Mark The Droner
    Does a rapid and pounding heartbeat coupled with waves of hyperventilation count?
  13. The Suburban Hippie
    I think it is a neuromuscular problem. try taking a break after your first flight, and holding the transmitter in a different position. Try to see if it is positional.
    As light as the tx is, you may actually be getting muscle fatigue from standing in the same position. You can try some weight training.
    First try moving around, and moving the position you are trying to hold the tx in.
    If it continues to get worse, see a doctor. I am not kidding.
    It is likely nothing.
    I know this because I have had some neuro damage in the past.
    I get shakes in my left hand when I am coming in for a landing. However for me, I know what it is. It is the neuro damage coupled with holding my thumb and body in the same position.
    Some training will probably alleviate the problem. I don't mean this as a cut, but it could just be you are a little "weak" in that position, and your body gets fatigued.
    Think of yoga, and how fatigued people get when standing in the same position... If you don't know about yoga, ask someone, or try it and you will see.
Similar Threads - Does anyone else Forum Date
Does anyone else get this? Phantom 4 Pro Help Aug 7, 2017
does anyone else polish their drone Phantom 4 Discussion Jun 12, 2017
Does anyone else get long range flights with their P3S stock? Standard/4k Discussion Mar 27, 2017
4k Hdmi module won't fit P3 4k wrong ribbon cable Does anyone else have this problem? Phantom 3 Help Dec 23, 2016
Does anyone else's P3 battery look like this? Pro/Adv Discussion Mar 7, 2016
