Every time I fly. My Adroid DJI Pilot display freezes with a NullPointerException in the java code. The internals of the app continue to record but the lightbridge video and stats do not update. Sucks so bad but until I can get a better tab I stay close to LOS.
Only when I forget my effing lightning cable. I still forget that sometimes, too used to P2V+Do you guys fly 'commando' sometimes?
Samsung Galaxy Tab 3 rooted with CF-AutoRoot. I think I need to just wipe it, reload the factory rom and start over. I prefer it rooted because it allows me to delete all the bloatware but it may be interfering with the app. Not sure.What device are you using?
I've been reviewing the Crashlog.txt files and it seems to be a nullpointerexception causing Java to crash. For some reason DJI Pilot is using a reference that points to no.location in memory (Null) instead of an object. I'm still reviewing the values to try and determine which are causing the exception. It always happens around the 3 minute mark of my flight.Try downgrading Google Play Services component as it appears to help in the majority of cases
http://www.phantompilots.com/threads/check-out-this-guys-near-miss-with-rth.48031/page-2#post-450666
There's a lot of bloat with the Samsung devices, but I don't think they're really using up that many resources in the grand scheme of things - the pilot app is a CPU hog. I used a custom rom and it's not made much if any difference.
I'm going to create a AVD in the Android SDK that replicates my Tab as close as possible to test thePilot App make sure it's not just my device. I wish I had the DJI SDK as well but I aint got time for that right now
True. Rarely does the everything work in the emulated environment. OK I downgraded the Google Play Services. I'm going to go fly it around the pasture real quickYou could try but you're not really going to be able to replicate the environment, as I doubt you can get USB debugging going on a PC interface in order to plug in the RC. I was considering trying on Bluestacks, but then I though bugger that, my Surface Pro 3 would be to heavy to use as a tablet.
I doubt it's your device. The Google Play Services downgrade might be your ticket, just a pain if you use the other google suite of apps on the same device as some will no longer be able to run.
Just Horses and dogs tonight!!Good luck. Watch out for drunk chicks
You are a frikin genius Scotty!! Freezing issue SOLVED!!!! 4 full battery flights and not a single display issue!! However, I didn't have an SD card in so tomorrow I'll record at 4K but it was better than I have had since I started flying. Thanks mate!!Good luck. Watch out for drunk chicks
Worth the extra payout. I should get a commission. Hahaha
RedHotPoker
